2009 Jaguar XF; Squeaky Steering Wheel
Old Jul 24, 2018 | 07:47 PM
Dallas Rockford's Avatar
Default 2009 Jaguar XF; Squeaky Steering Wheel
I've heard of this problem with other models, but not the XF.
My steering wheel creaks / squeaks like a door in a horror movie. Steering fluid seems at a good level.
Anyone have this experience? If so, any solutions?
Old Jul 24, 2018 | 08:46 PM
OzXFR's Avatar
Try spraying some PTFE spray all around the steering wheel shroud while moving the wheel up/down and in/out.
Old Jul 27, 2018 | 04:51 AM
les's Avatar
les
In the X350 XJ the steering could have a squeaking noise, it was quite common. It was cured by putting an additive in the fluid.
Old Jul 27, 2018 | 08:13 AM
pdupler's Avatar
Not on the X250, but on the X308 I had a creaking noise like the old screen door on the TV show "The Waltons". I just assumed it was the clock spring mechanism so I went to a local Jaguar salvage and bought one even before I took it apart to investigate. Turns out it was instead the four springs that the airbag unit was mounted on. As the steering wheel was turned, the weight of the airbag would shift, causing the springs to move in their seats and make those creaking spring noises. Some tacky dielectric grease coating those tiny springs and seats cured the noise. I have never taken the XF's airbag off so I have no idea if its mounted similarly. Come to think of it, I don't remember if I even honked the horn.
clint25n
62
Jul 3, 2024 07:35 AM
carzaddict
Aug 24, 2016 03:35 PM
coastaljag98
Nov 10, 2012 04:42 AM
BuckMR2
Jun 23, 2011 09:03 AM
bojangles
May 22, 2009 10:31 AM
