2009 Jaguar XF Headlight repair
Old May 23, 2017 | 09:17 PM
JamesT81!'s Avatar
Default 2009 Jaguar XF Headlight repair
My passenger side headlight stopped working about 2 weeks ago, I brought my car in to the Jaguar dealership and was told that the wires overheated and melted the rubber cording, then shorted out when they touched wire to wire. They estimated total cost for the repair on that was $1000. Which I do not want to pay. Is there another (cheaper) fix for this? Has anyone had this issue already and had it repaired at a cheaper cost?
Old May 23, 2017 | 09:34 PM
Mr Sharky's Avatar
If it is only a wire issue, then one can simply replace the bad one by splicing in a new wire in its place where it is bad. The dealer is accustomed to replacing the entire harness. This is why the cost is higher. You can splice in a new one and solder the connections (better repair) or replace the entire harness (best repair). They both will work well.
Old May 24, 2017 | 06:30 AM
mark campbell's Avatar
you may want to check why it got hot --ie maybe replace ballast and/or bulb igniter just a thought
motorcarman
General Tech Help
647
Mar 11, 2026 02:53 PM
JimC64
Sep 22, 2025 02:52 PM
Opaquer
Oct 13, 2016 05:56 AM
Joe S
Oct 6, 2016 08:29 PM
