2009 Non supercharged XF fluid changes
Old Apr 22, 2014 | 06:05 PM
nasa25's Avatar
Default 2009 Non supercharged XF fluid changes
According to the owners manual, only the following fluid changes are required for a 2009 4.2 NA XF:
Oil changes every 10k miles
Brake fluid flush every 3 years
Coolant flush every 100k miles (or it could be 150k - the actual number escapes me at the moment).
As far as I know, transmission and power steering fluid is supposed to be lifelong and changes aren't required. Also, might sound stupid but Im not sure whether or not there is a requirement to change differential fluid or whether or our XF's even have diff fluid.
Should I be looking into changing transmission, power steering and (if required) differential fluids? I'd rather be safe than sorry with the supposed lifelong fluids.
Old Apr 22, 2014 | 07:09 PM
*Phoenix*'s Avatar
Originally Posted by *Phoenix*
Save this one while it is still up.
http://www.jaguar.com/content/market...sporttoservice
Here you go.
Old Apr 22, 2014 | 07:14 PM
nasa25's Avatar
thanks.
I'm particularly interested in the fluids that are not specifically mentioned in the passport to service and whether or not its prudent to actually change the supposed life long fluids.
Old Apr 24, 2014 | 07:25 PM
jagular's Avatar
The transmission is sealed and has no drain. The only reason it might need a fluid change is if it is used in "severe service" which basically means trailer towing and then at 80,000 mile intervals.
The differential has regular differential oil in it and needs no fluid changes.
The coolant is ten years or 100,000 miles between changes.
The spark plugs are 100,000 miles between changes.
This car requires only engine oil changes and brake fluid flushes.
ryan_border
Dec 23, 2015 04:27 PM
vwbusbits
Oct 13, 2015 03:43 AM
Poet
Oct 2, 2015 09:00 AM
dieseldoc
Sep 28, 2015 01:17 PM
Woznaldo
Sep 26, 2015 11:02 AM
