2009 XF 2.7 diese l- Transmission oil cooler access
Old Jun 23, 2023 | 05:21 AM
PhilipEichler's Avatar
Default 2009 XF 2.7 diese l- Transmission oil cooler access
I have a 2009 XF 2.7 diesel. Transmission oil cooler has failed allowing some engine coolant into the transmission. Does anyone here know if it is possible to remove the old cooler and fit the new one from under the left front mudguard?
Old Jun 28, 2023 | 08:09 PM
As it turns out I was able to remove the cooller from through the space behind the left front wheel. If you do this job be aware the plastic base the cooller sits on has to be removed first. I did remove the air cleaner box to give me better access to disconnect and reconnect coolant hoses.
Comradboris
Jun 13, 2023 10:40 AM
tmich
Oct 4, 2021 05:04 PM
Taewhoon
Feb 13, 2019 10:31 PM
Daim
Jun 3, 2016 12:40 PM
Golla
May 21, 2014 05:53 AM
