2009 XF SC Ballast Issue?
Old Dec 23, 2014 | 01:48 PM
Gpalace's Avatar
Default 2009 XF SC Ballast Issue?
Hi Gents,
Suspect I may be havig an issue with the ballast for my headlight.
Passenger side will just go out for a while...than try it later or next day and light works perfectly.
Are there any known or recent issues that you guys may be aware of ?
Also, if any of you know the location of it?
Many thanks as usual!
Gpalace.
Old Dec 28, 2014 | 12:09 PM
jagular's Avatar
A lot of European owners have complained about a wiring problem giving these symptoms. Apparently the OEM supplier has a fix in the form of a pigtail extension, at least I think this is the fix. A Jaguar dealer should know.
Old Jan 5, 2015 | 02:36 PM
Gpalace's Avatar
Thanks! Had my mechanic investigate and he swapped a Ballast and a Headlight from side to side and is working for now...depending on which side does go out we will know what to change..thamks for the heads up on the pigtail extension possibility.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Richxk8
Sep 16, 2015 10:57 AM
avern1
Sep 8, 2015 06:25 PM
chris4579
Sep 8, 2015 04:34 AM
