2011 Jaguar XF 2.2d passenger door lock problem
Old Jun 26, 2015 | 09:17 AM
Antoine Galea's Avatar
Default 2011 Jaguar XF 2.2d passenger door lock problem
2011 jaguar xf 2.2d. when car is unlocked via key fob, lock seems to try to budge but doesn't unlock. latch as to be unlocked from the inside for the door to be able to be opened from the outside
Kindly see video linked below:
As i said, door seems to be trying to get unlocked, but not travelling enought outside
Any idea as to the culprit would be of immense help
Old Mar 5, 2016 | 04:46 AM
SOLENTBONES's Avatar
Just had problem, everything appears to lock but stranger without key fob opened drivers door. On checking drivers door, all appears to lock but in fact does not. Removed door card IAW instructions posted and found cable not properly seated in handle mechanism. Small push and piece of masking tape to hold it while I wrestled panel back on with all connections and it works fine, 40Mins and a garage bill saved!
Old Mar 8, 2016 | 10:51 PM
JBzXJ40's Avatar
I have seen on a few occasions where the cable on the inside of the door panel comes loose, there should be a small metal clip there that prevents this. Otherwise, it will be the door latch, they are a common problem on the xf's.
Old Mar 9, 2016 | 11:33 AM
Default loose bits in door
Thanks I will check the bottom of the door for a clip!
hafren
Aug 30, 2023 03:42 PM
msdg137
Sep 16, 2015 06:24 AM
MarathonJohn
Sep 3, 2015 07:59 PM
frankc
Sep 1, 2015 04:41 AM
Tony Bow
Aug 28, 2015 05:17 AM
