2011 xf 5.0 water pump
Old Apr 20, 2015 | 11:54 PM
Cactus139's Avatar
Default 2011 xf 5.0 water pump
I replaced the water pump in my 2011 xf 5.0 v8. When I took it out there was a black hose with a little 90 degree plastic fitting that went right into the water pump by the pulley. I have tryd everything to figure out where to get one and still no leads. Hopefully y'all can help out thanks
Old Apr 21, 2015 | 12:17 AM
OzXFR's Avatar
Try here:
http://www.partswebsite.com/jaguarpa...42&catid=10011
Old Apr 21, 2015 | 08:01 PM
jaguny's Avatar
You should still be under warranty unless you've exceeded the mileage limit?
Old Apr 26, 2015 | 10:51 AM
davetibbs's Avatar
Having just replaced this hose on my (out of warranty) 2010 5.0 XF, I can tell you why you can't find the pipe - it's been discontinued!
They've changed the design of the pipe as well as the larger pipe that goes from the thermostat to the metal pipe above the throttle body. I'll try and dig out the invoice later and get you the part numbers.
Wahooesprit
Dec 23, 2019 02:01 PM
picard
Oct 12, 2015 11:56 AM
Jaiello21
Sep 14, 2015 09:42 PM
mikimogo
Sep 14, 2015 08:34 PM
chatmanx
Sep 11, 2015 07:17 PM
