2012 Jaguar xfr fuse box question ..
Old Mar 5, 2025 | 11:03 AM
Sancho20's Avatar
Default 2012 Jaguar xfr fuse box question ..
Anyone know how to remove the fuse box under the hood ...trying to change upper control arm and can't get to the bolts without removing the fuse box.Or maybe theres a way to change them without removing it ..I searched hi and low all over the Internet and can't find any answers ...Any help would be greatly appreciated..
Old Mar 5, 2025 | 05:51 PM
POD XF's Avatar
I just had a look at the thread on my engine removal but unfortunately no pics of removing the fuse box; I seem to recall there were 3 bolts holding it in, two from above and one down beside the engine. Pretty sure I needed to remove all the trims around the fusebox to access these, also the r/h air cleaner assembly.
Old Feb 15, 2026 | 03:33 PM
JagMeow's Avatar
I’m doing this exact service on my 2011 XFR and I cannot get the fuse box out or reach the upper control arm bolts at all. Did you ever figure this out? Drivers side was a breeze, but the passenger side is completely different and has no access with the fuse box and everything else in the way.
Old Feb 19, 2026 | 06:52 AM
dennis black's Avatar
20 Year Member
The fuse box is not removable
what you have is 2 10mm bolts and a 8mm bolt to remove, then lift it up
and move it ot the way,
Kurt Iseli Jr.
Jul 13, 2024 04:53 PM
Joba
Mar 13, 2021 07:06 AM
JagQ
Aug 29, 2019 11:33 AM
lenavarrete
XJ40 ( XJ81 )
Jul 20, 2018 11:33 PM
nairnman
Nov 10, 2010 05:03 AM
