2012 XF Portfolio V8 Gas Gauge.
Old Jun 22, 2020 | 07:02 PM
wjgesq's Avatar
Default 2012 XF Portfolio V8 Gas Gauge.
Was reading about 3/4 full.
Suddenly the warnings come on the dash. It’s showing empty.
it’s obviously not empty.
Turned it off. Turned it on. No change.
ideas?
Common problem?
Car has like 48k miles.
Old Jun 23, 2020 | 09:37 AM
I've moved your question from X260 to X250 forum. This is the place for questions about your 2012 model.
Old Jun 23, 2020 | 10:00 PM
davetibbs's Avatar
This is a known issue with the connectors on the fuel level sensor on the pump module that sits inside the tank. I've attached the TSB that describes the issue and how to fix it, along with the workshop manual section to remove it.
I'd recommend a fuel ring removal tool as mine needed not only this but a breaker bar with a cheater bar on top, but apparently others have had success removing theirs with a screwdriver and a hammer.
File Type: pdf
Old Jul 8, 2020 | 08:19 PM
wjgesq's Avatar
Thank you so very much.
Very nice of you to provide that information.
If this is done buy a Jag dealer, what kind of price should I expect?
Old Jul 8, 2020 | 08:54 PM
davetibbs's Avatar
Afraid I'm pretty DIY so I don't have that answer, others might. Worst case, give them a call?
Old Jul 10, 2020 | 01:15 PM
Richard Zuniga's Avatar
Default same problem kind of
I can fill my tank but it'll show that there's 1/8 or so less
I can go back and keep doing the gas pump till it kind of shoots out some fuel from the filler and itll still show about 1/8 leas than full
hopefully extended warranty covers it
Old Jul 10, 2020 | 01:44 PM
davetibbs's Avatar
Definitely the same issue as in that TSB I posted above - those were the symptoms I experienced.
Mrsplumblao
XF (X260)
Jun 7, 2019 05:52 PM
spanky145
May 24, 2015 12:14 PM
spanky145
Nov 22, 2013 11:45 AM
