2013 xf fan problem
I have the same problem. A/C stopped working when not moving cause fan is no on or spinning very slowly. I think it might be the fan speed sensor which it is build into the fan. Thinking about ordering a used fan and replacing. Brand new from Jaguar is like $900.
hello everyone, I'm Gérald b and have a jaguar xf 2.2 from 2014 but the cooling fan no longer turns! no more air conditioning! , I checked the wiring, fuses and connections, all is good, when I put the air conditioning, it starts for 1 second and nothing! at the terminals of the fan plugs, I have: 12 votes on the big wires and also 12 votes on the other 2, do you think the fan is out of service (HS)?? , I don't know how to test it? I look forward to your answers and advice!!
I'M ALSO LOOKING FOR:
the cooling fan motor control diagram! I am an electrician with good knowledge of electronics and think I have a chance to find the defective part (because many problems with this engine) which could help many people of course of this jaguar
I received the iCarsoft LR V3.0 diagnostic case, it tells me the fan is faulty, I also received the fan BUT not the correct one! so return and new order, hard to find in France: ordered in Lithuanian on the Ovoko site, I also saw it on Ebay United Kingdom but no shipping to France? , news from reception
I went to Jaguar Vesoul in France (because I'm French) here! it's catastrophic, they told me that they hadn't found the fault and offered to change them piece by piece!!! are certainty of repair !! this is why I turned to you!
thanks in advance ! friendly gerald
M12345678
Jul 14, 2016 12:49 PM
