2013 XF Grille Badge Replacement
Old Sep 27, 2015 | 07:34 PM
OzXFR's Avatar
Originally Posted by hlgeorge
I need to do this upgrade. It looks awesome! It will really stand out with a red car too.
You painted it right?
Yep, per his earlier post he disassembled the badge and spray painted the backing.
I did the same with my grille badge, except I did the backing in body colour (Kyanite Blue) using an artists brush and the touch up paint from my ChipEx kit, then two coats of clear lacquer on top.
The badge is easy to lever off with a plastic trim removal tool, then it's easy to pull apart into it's three pieces, paint the backing, then reassemble and stick it back on.
alcrawjr's Avatar
Hey Lew yes it would look great on your red XF. To answer your question. Yes I did spray paint over my black growler badge. The bad is 3 different sections. You simply pry the apart and when done painting you snap them back together and either use 3m tape or an apoxy to put it back on your grill. It only took me two minutes to get mine off. I used a can of $3 can of gloss red paint. I let the part dry over night before putting it back together. Please post pictures after you're done.
Old Jul 28, 2021 | 06:21 PM
jrz813's Avatar
hey everyone I have a 2011 Jag Xf as well and I was wondering where I could buy the emblem? To be honest I'd rather just keep the original in case anything might happen... I'm looking for a red one as well of course.
Old Jul 28, 2021 | 08:08 PM
dennis black's Avatar
pulling the bumper is a 35min job not so bad ,at tthe end of this video you will see me doing it ,but ill make a better one stet by step
Old Jul 29, 2021 | 10:22 AM
ddanielcigars's Avatar
Default Changing Grill Badge
Originally Posted by 1stJAG_XF
I would like to change the growler badge on the front grill of my 2013 XF from the standard black to the red growler badge. Is there a quick and easy DIY method to do this?
See my post below. It’s super easy and only took about 15 minutes.
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 3, 2015 07:32 PM
davidladewig
Sep 3, 2015 06:32 PM
