2013 XF throwing lots of error codes
Old Jul 31, 2025 | 06:13 PM
Enzos Dad's Avatar
Default 2013 XF throwing lots of error codes
I have a 2013 Jaguar XF (US edition) that started throwing a bunch of codes starting about two months ago. At first they were very intermittent, now they happen about 5 minutes after the car starts up. The car runs fine (unless one of the codes forces it to “limp” mode). I can clear the codes with a cheap OBDII analyzer (except the permanent codes). Here is an example of the codes that can appear on the display in one session:
1. Battery not charging
2. Special modes not available
3. Gearbox fault
4. ABS Fault
5. DSC not available
6. EBD (?) fault
7. Emergency brake assist not available.
To date I have bought a new battery, removed the ECU from the engine compartment and cleaned all the connector terminals, removed the Central Junction Box from underneath the passenger side dash, examined it for corrosion (a known problem) – didn’t see any but cleaned all terminals and connectors anyway.
At this point I have run out of ideas, any suggestion gratefully received.
Old Feb 24, 2026 | 02:24 PM
XKDreams's Avatar
Have the charging system checked out by a service tech. And have the battery load tested. Reading full battery voltage doesn’t mean it isxgeakthy.
Old Feb 26, 2026 | 01:25 PM
John Williams's Avatar
Basics first, check battery terminals!
Old Mar 2, 2026 | 06:49 AM
dennis black's Avatar
Did you reset the bms with a scan tool
Old Mar 3, 2026 | 05:41 AM
webb 72's Avatar
Think your wasting your time with this one
He hasn't been around since last August
Old Mar 3, 2026 | 07:23 AM
clubairth1's Avatar
Community Influencer
Can you post the codes? The actual numbers. That makes a difference.
Rob.hambleton
XF (X260)
Dec 18, 2023 06:42 AM
Jkrn78
Jul 18, 2023 07:13 PM
mesaboogieman
Jan 28, 2020 01:03 AM
Jamiemccowat
XF (X260)
Jan 14, 2018 06:24 AM
Mihael
Aug 16, 2010 10:35 AM
