2014 XF Front and Rear Suspension?
Old Jun 18, 2021 | 07:48 AM
Luke2004xjr's Avatar
Default 2014 XF Front and Rear Suspension?
I just had both my front lateral control arms replace, both lower control arms replaced, both rear stabilizer bars link replaced, both front shock absorber mounts replaced. Then after 600 miles the steering was not straight, and my front tires on the inside are now bad, and i know that is because the camper must be way off. I also noticed that both new upper control are bushing boots are already cracked in the rear. My guess it that it was installed incorrectly? The dealer is replacing the parts, and the front tires at no cost, So I am happy for that. The other question that is troubling me, is they said that the suspension may have settled? If that is the case, then how long till I should bring my car back to have the alignment re checked? If that were the case, then most new cars would have to be brought back for alignments?
Thanks all
Old Jun 18, 2021 | 08:13 AM
tapau's Avatar
I also have a 2014 XF 3.0 and had my front & rear suspension control arms & shock/strut mount replaced last year. I also got new tires and brakes around the same time (within of month). Haven't had any problems,
I call BS on the "suspension may have settled"
No way this should have happened to you.
I would call Jaguar NA and complain. Good luck.
Wingrider
Aug 28, 2017 05:17 AM
David Gonzalez
Jul 13, 2017 08:22 AM
LarryGeorge
Sep 11, 2016 11:05 AM
wesmc
Nov 18, 2014 08:17 PM
Adam Lueb
Sep 14, 2010 04:21 PM
