2014 XF Garage Door Open - No Fast Flashing Light
Old Aug 30, 2024 | 06:14 PM
Cenlac's Avatar
Default 2014 XF Garage Door Open - No Fast Flashing Light
Hello everyone,
I just recently purchased my first Jaguar, a 2014 XF with 32,000 miles. I love the car. But I can't get the garage door to program. I have search high and low, but can't find a solution. I can never get the light to flash fast. I goes from slow to off. I tried using my remote and the rolling code method. I can't get either to work. I'm desperate for help.
Old Aug 30, 2024 | 07:53 PM
GaiaXF-V8S's Avatar
What brand garage door do you have? At my old house I had to buy a special transceiver to get it working because it was a LiftMaster garage door system.
Old Aug 30, 2024 | 09:33 PM
Cenlac's Avatar
https://www.youtube.com/watch?v=pqi5lJPHl-E
Thank you so much! I have a Liftmaster. I will order this right away.
Old Sep 1, 2024 | 09:10 PM
Cenlac's Avatar
I got the device I today. I was able to get it to flash fast using the home link remote. I clicked the learn button on the opener, but it never connects with the car. I've ordered a replacement just in case the device is bad. If it doesn't work with it, could it there be a problem with the open itself? I have a 2009 SL550 that works with it fine. Not sure if that matters.
Old Sep 2, 2024 | 08:09 PM
Cenlac's Avatar
I finally was able to get it to program. The issue is my learn button on the garage door opener. I was able to get it to pair up when I used the learn button on my wall control. I still needed the hub connector you suggested in order to complete the first step. Tha k you for your help. It is very much appreciated.
Old Sep 4, 2024 | 10:22 AM
clubairth1's Avatar
Community Influencer
Glad to hear you got it working. I had to add this bridge to my garage door opener too. It took some messing around before I could get it all talking to each other. But happy I took the time to do it.
raptor72
Jun 18, 2023 04:52 AM
clotheshorse
May 14, 2020 09:08 AM
Haugen
XF (X260)
Feb 19, 2019 07:44 PM
Ashlev63
Jun 9, 2017 03:40 AM
jasonzimbran
Nov 1, 2015 09:34 PM
