2015 XF Headlamp Fuse?
Old Jan 30, 2025 | 09:14 AM
Nikana Walker's Avatar
Default 2015 XF Headlamp Fuse?
On my 2015 XF 3.0 / 3.6L R6, the passenger headlamp has gone out, including the highbeam. My first thought was to check the fuse as both low and high beams appear to have gone out simultaneously. Upon review of the owner's handbook and online source1 and online source2, it does not appear there is a specific fuse for the headlamps. Here is what I find;
Engine Compartment Fuse Box
  • Fuse MINI5A F28 Adaptive front lighting - LH
  • Fuse MINI5A F29 Adaptive front lighting - RH.
  • Fuse MINI5A F39 Headlamp levelling system
Interior Fuse Box Panel
  • Fuse MINI5A 23 Driver's seat. Audio system. Auto headlamps. Upper centre console switches
    • this is listed in the online resource, and not my owner's handbook
None of the fuses listed in my manual appear to be what I am looking for, unless I am misunderstanding something.
Also, in the event that it is relevant, I understand from the service department at my local dealership that there can be 2 unique setups for changing headlamps, one of which would cost me approx. $4,000 to get changed! From my S/N, they were not able to tell me which setup I have.
In reviewing what appears to be the definitive thread on this subject, https://www.jaguarforums.com/forum/x...-thread-82098/, I am not finding anything about fuses, nor how to detect which headlamp system I have.
All clarification is welcomed.
Thank you in advance.
Old Jan 30, 2025 | 02:53 PM
John Williams's Avatar
They have FET's
​​​​​​Field-effect transistors (FETs) can be used in circuit protection to protect against voltage surges, overcurrents, and other events.
Old Jan 31, 2025 | 09:02 AM
clubairth1's Avatar
Community Influencer
Swap head lights from side to side. That will get you started.
Post back what works and what does not.
captbob73
Dec 15, 2024 06:33 AM
Jaaaggg
Jul 20, 2024 10:08 PM
sogood
Nov 20, 2022 05:48 AM
OUScooby
Dec 31, 2019 09:48 PM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
