5.0 Broken Timing Guide
Old Jun 27, 2021 | 04:30 PM
xfportfolio's Avatar
Chineese tools are crap, when I tried to tighten the crank pulley bolt the socket from aliexpress got rounded and I couldīnt finish the job properly (I couldīnt rotate the bolt 270š).
Look at this video, 8:06 and 20:27
Old Jun 27, 2021 | 04:37 PM
CaptnJack's Avatar
I read that about the socket in another thread, somebody made the recommendation to still buy the factory socket if buying a cheap tool kit.
Old Jun 27, 2021 | 05:41 PM
davetibbs's Avatar
That sounds like a good recommendation for the socket, or at least get a good quality impact socket. The only thing is, if you're using the crank pulley tool which goes against a jack stand - and honestly, I recommend that you do use one of these, chinese copy or not, it can be tricky to find a socket deep enough to clear the tool, and it's hard (but not impossible) to do with (eg) a smaller socket and an extension bar. I'll see if I can find a link to the one I bought.
These bolts are on tight (which is why the information about identifying which way the bolt is threaded is so crucial, there's been tales of snapped bolts on here which = replacement crank). Prepare for cheater bars or at least a high torque impact gun once you know which way to extract the bolt.
Old Jun 27, 2021 | 07:48 PM
OzXFR's Avatar
2010/11 XFR Workshop Manual here: https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
AJ133 Training PDF here: https://www.dropbox.com/s/8y4iax9hm2...%20V8.pdf?dl=0
Old Jun 28, 2021 | 03:51 AM
kansanbrit's Avatar
Originally Posted by CaptnJack
Thanks for all the help kansanbrit! Is it possible to do the timing chains with the engine in the car? I don't have a lift at home and would like to tackle this job in my garage.
I'm sure I'll have many more questions along the way.
You can try but I think you will find it extremely difficult, removing the injectors will be almost impossible if they are as tight as some I have removed.
I use these tools for the pulley.....
Tools
Old Jun 29, 2021 | 07:12 PM
CaptnJack's Avatar
Thanks for all the links and advice guys!
I should be getting it tomorrow but won't be able to dive into it for a week or two. I'll keep this thread updated with what I find.
Old Jul 1, 2021 | 05:16 PM
CaptnJack's Avatar
Well I got it home yesterday! Hopefully next week I can start taking the front timing covers off to see what's going on.
George05
Jun 29, 2021 06:51 AM
Cheddarfish
Apr 8, 2021 02:25 PM
JensenHealey
Dec 23, 2018 04:16 AM
TN8Shooter
Sep 30, 2012 09:16 PM
filoli1993
Dec 17, 2010 01:40 AM
