5.0 S/C Engine Rebuild
Old Dec 31, 2017 | 11:54 AM
  #121
Cherry_560sel's Avatar
When I was trying to look for a place for my controller, I took a look at the space behind the sunvisor. There is quite a bit of space up there and if the install is done right, you may even be able to keep the sunvisor in place. Don't know what size gauges you are looking to put in, but if the purpose if for monitoring every once in a while, then the headliner would be much easier. Putting them in the middle of the dash places them out of the normal line of sight anyways, plus creates so much custom re-work. You could also use the middle speaker area. Just pop off the grill and create a little bubble for the gauges.
Old Jan 16, 2018 | 07:29 PM
  #122
davetibbs's Avatar
Project still not dead. On the upside, these turned up today. Custom forged pistons made from 4032 for it's low expansion rate and resistance to wear, and costed in phosphate and grafal. Awaiting resized conrods with ARP bolts.
Old Jan 18, 2018 | 11:55 AM
  #123
f-driver's Avatar
Hi Dave ,
these piston look great . Did you order them directly from Mahle Motorsport or by
an other company ? Were they build according to a technical drawing or by suppling
a sample part ?
I can't imagine this packet being cheap ;-)
Regards
Ulrich
Old Jan 19, 2018 | 12:58 AM
  #124
davetibbs's Avatar
Hey Ulrich,
I ordered them direct from Mahle Motorsport - I sent a used factory piston to be laser scanned as a model. I'm not sure I'd describe the packet as "cheap", but I thought $200 per piston was pretty reasonable, given that a factory piston is significantly more expensive.
Old Jan 19, 2018 | 01:21 AM
  #125
f-driver's Avatar
Hi Dave,
thinking about how many manufacturing steps have to be done and how many different
machine tools you need to build a high performance piston as an individual item
this price is a bargain for sure.
Did they built the pistons according to your (reworked ?) cylinder liner diameter ?
Regards
Ulrich
Old Jan 19, 2018 | 11:24 AM
  #126
davetibbs's Avatar
They actually requested the cylinder bore be honed to a particular size (3.643") which I had a machine shop do before the pistons were ordered.
Old Feb 5, 2018 | 12:37 PM
  #127
Alsaropolis's Avatar
I am new here, and help Badly, lol, I just got a XFR 2011 , ONLY 40K. MILLES ON IT, GOT IN ON AUCTION, WITH KEYS PRESENT, RUN AND DRIVE, CAR CAME FROM US, CLEARED CUSTOMS,
KEY WAS NOT FOR CAR, WELL FU..... IT. , I MADE NEW KEY JAGUAR, CAR DIDNT EVEN TURN OVER!! Checked engine. There is water in it! losed plugs, and found that engine goes only. 1,5 turns around, so pro-ably bent a connecting rod as water got into engine! Called jaguar. , they said I can’t order connecting rods , only engine, Well can’t afford that,
Old Feb 5, 2018 | 12:40 PM
  #128
If anyone could help with diagrams of timing, should I watch out for any things when dismantling etc. like in Mercedes m 273 engine, the timing sprockets have to. Be secured with pin, if not they will release the spring and can’t be reused! Any hidden tricks here? Also if anyone knows. Where I might get parts , used, new anything.... thanx guys.
Old Feb 5, 2018 | 01:12 PM
  #129
davetibbs's Avatar
In terms of timing, you'll be wanting One of these kits to lock it. There's a workshop manual for this engine kicking around, or available online. Parts are not available through Jaguar but can be sourced elsewhere, I've posted some links throughout this thread where I got bearings and conrods.
Old Feb 17, 2018 | 02:02 AM
  #130
Talking Timing tools
Good morning<
so took appart my jaguar 5.0 sc. and found that in the end was Nothing WRONG, EXEPT RUST IN CYLINDER BORE STOPNIG ENGINE FROM TURNING, SO WILL HAVE IT HONED A LITLE, AND USE THE SAME PISTONS AND PROPABLY RINGS ALSO, TOP gaskets will go new, And will try couple, MY PROBLEM NOW IS TIMING TOOLS, any info as to where one can order those, Jag said they would couple my engine, AT 108 USD PER HOUR!!! 23 hours of work!! Fuc....... them....... will try it myself
Old Feb 17, 2018 | 07:38 AM
  #131
Rique's Avatar
Originally Posted by Alsaropolis
Good morning<
Did you check the kit that Dave recommended? Here is a link to one on ebay. I got one and its pretty good. I have not used it yet. Pictures of your tear down would be appreciated. How did you get the fuel injectors out? I'm at that stage. I need to change my head gaskets.
https://www.ebay.com/itm/Jaguar-Land...oAAOSwB9xXPHgD
Old Feb 17, 2018 | 07:48 AM
  #132
Rique's Avatar
Service manual recommends what changing Head Gaskets to use one step thicker if available. Any body know if there are thicker head gaskets? So far I have only been able to get standard set.
Old Feb 17, 2018 | 09:12 AM
  #133
Default Injectors
The injectors are impossible to remove without a tool,!! Too hard, you need a 🔨 tool,it hooks to the injector then on rod connected is a heavy peice, so it's like hammer in reverse.
the gaskets in jaguar are 2. Layer. And 3 layer, but in the end it goes to one number, and l get the thicker propably.
Old Feb 17, 2018 | 02:40 PM
  #134
davetibbs's Avatar
I've bought these head gaskets from Cometic for my rebuild. They are 4 layer.
Old Feb 18, 2018 | 08:50 AM
  #135
Rique's Avatar
After trying unsuccessfully pulling the injectors this is my next step.
I got this part and am using a slide hammer which is what I think you are
using too.
I'm glad there's three of us working on the 5 liter engine. We hold responsibility toward our Jag community to share tech info. Dave and you off course have advanced far more than I. Good luck.
Attached Thumbnails 5.0 S/C Engine Rebuild-slidhammer.jpg   5.0 S/C Engine Rebuild-inector-pluller.png
Old Feb 18, 2018 | 11:54 PM
  #136
Default Ya this will work
This Shoukd get injectors out, heading to Afrika for 10 days, will order the timing kit, and head gasket, and honing tools, and assemble engine early March
.... Then will see if it starts, lol 😁
Old Feb 26, 2018 | 09:19 PM
  #137
Asheal88's Avatar
Have a car that looks wise is almost in perfect condition, but needs a new rod bearing. I was SHOCKED to hear that you cannot just replace the bearing and Jaguar wants me to buy a whole new engine.
So shocked that I basically said I am done with jaguar. I have a post up for anyone who wants to buy a gorgeous car that needs a new engine, dirt cheap if you want it. Just trying to get enough posts so I can get it up for those interested.
But for how hard it is to work on these things including reading through this entire thread, it is sad that Jaguars seems to make "throwaway cars"
Old Feb 28, 2018 | 12:53 PM
  #138
Default Where you located,
What model and year is it, and how much u want for it,
yes the engine issue is a catastrophic thing, jaguar USED XFR ENGINE IS LIKE 10,000 USD, THEN u still need to swap them, ..... It sucks,
Old Feb 28, 2018 | 12:58 PM
  #139
Default Mine
Old Feb 28, 2018 | 01:01 PM
  #140
Default Interior
