5.0 S/C Engine Rebuild
Old Mar 1, 2018 | 12:51 AM
  #141
Bigg Will's Avatar
Still with ya buddy!
Old Mar 1, 2018 | 12:53 AM
  #142
Bigg Will's Avatar
And since it seems unfair to drag this thread back up without anything of substance, have a teaser photo of something I was going to wait to reveal but I'm quite excited about: custom oil temperature, pressure, and boost gauges designed to match my factory instument panel, made by New Vintage USA. The quality is fantastic - the paint is silver like the factory gauges, and I haven't had a chance to compare the backlight color but it looks pretty good from the photos they sent of them illuminated.
I'm planning on some custom dash work to mount these but that can come after the engine has been rebuilt. As for why I got them: I'm not putting this much time, effort and money into rebuilding this engine without having some sort of a telltale as to if it's going to break again!
If anyone else is interested (though you might want to see how the dash gauge mounting goes first, lol) I'm sure they've kept the design files to make more.
You could do a Canton Mecca oil occumalator?
Old Mar 1, 2018 | 07:52 AM
  #143
wardo5757's Avatar
Originally Posted by Alsaropolis
Good morning<
so took appart my jaguar 5.0 sc. and found that in the end was Nothing WRONG, EXEPT RUST IN CYLINDER BORE STOPNIG ENGINE FROM TURNING, SO WILL HAVE IT HONED A LITLE, AND USE THE SAME PISTONS AND PROPABLY RINGS ALSO, TOP gaskets will go new, And will try couple, MY PROBLEM NOW IS TIMING TOOLS, any info as to where one can order those, Jag said they would couple my engine, AT 108 USD PER HOUR!!! 23 hours of work!! Fuc....... them....... will try it myself
How did the cylinder was get rusted? That engine should be able to sit for a couple of years without being run and not corrode the cylinders.
That car must have sucked up water somehow??
Old Mar 1, 2018 | 11:44 AM
  #144
davetibbs's Avatar
Thanks man - just to give an update - life is incredibly busy outside of the car with a wedding, job change, immigration-related stuff and everything else, so the engine has been a bit neglected BUT it's ready to be rebuilt now, I just need to find the time (hopefully in a week or two).
Slight issue comes in the form of the shop that the car was being stored in was sold to new owners last week - I only found out from a friend who also had a car in storage there and went to visit before he planned to tow his car to Seattle. I went down there yesterday with him and the van/car trailer and felt the whole thing was too sketchy for me so we pulled the car out and back into my garage at home, which if anything should improve the rate of progress. I can easily get the engine into the car in my garage at home - transmission would probably require a lift to do it in all honesty so if the shop is still around under the new owners when I'm at that point I'll consider towing the car back down there to put the trans in (or just pay someone to do it at that point if I have to).
Old Mar 2, 2018 | 01:33 AM
  #145
Alexandr Grytsyna's Avatar
Hi,
I have the same engine on my RR SC and now in progress of finishing timing chain replacement, I replaced timing chain, tensioners and belts and after I assembled it back it shows misfires in cyls 2-4-6 and idle is rough. I hope I will fix it soon, so if you need any help with computer diagnostic or so - let me know) Will be happy to help.
Old Apr 3, 2018 | 06:11 AM
  #146
elviukai's Avatar
short video of 5.0SC rebuild done localy,near me. too sad its in native language.
https://www.youtube.com/watch?v=gSTz...ature=youtu.be
Old Apr 3, 2018 | 02:33 PM
  #147
Bart Lenferink's Avatar
Very impressive, most entertaining video in a long time. Well done man!
Old Apr 5, 2018 | 01:41 PM
  #148
Bigg Will's Avatar
Video really shows how long oil drain intervals will ruin these engines, first things to clog up will be all those small orifices and screens.
Old Apr 7, 2018 | 06:52 PM
  #149
davetibbs's Avatar
Thanks for that video! Looks like he had exactly the same issue I did with spun conrod bearings. Almost looked to be the same rods that spun too, but not sure on that.
Of particular interest is the timing chain guides shown at 8:13 in the video - his old one is on the top, the new one is on the bottom. The circular "hole" in the top one is not supposed to be there, and is the result of the infamous timing issue with the landrovers/jaguars that's been talked about a lot here recently. Mine had the same issue. What's interesting is that this seems to be being fitted into a facelifted XFR, and I thought it was only the 2010-2012 engines that had this issue - guess his might have been an early one?
BTW, the build up of my engine is imminent. I'll hit the thread with pics when I can. Sadly there may be a slight further delay as I haven't been able to clean up the block or head gasket surfaces properly and I'm worried about them sealing with the Cometic MLS head gaskets I've got for it, so I'm looking at getting the block and heads resurfaced before assembly. I may be overthinking it but I don't want to make a mistake I only have to tear apart and rectify later down the line.
Old Apr 8, 2018 | 12:14 AM
  #150
Bigg Will's Avatar
These guys have a whole series of AJ133 repair vids.
Old Apr 25, 2018 | 12:27 AM
  #151
davetibbs's Avatar
Sorry it's been so long - progress has been (as usual) SLOW, although I at least had an excuse, as I was busy organizing this:
However, back to the car. Here's a selection of some photos:
Block deck cleaned
Studs installed (with chopped one to clear baffle plate
Bearings installed
Crank installed
Pistons/Conrods ready to go in
Pistons installed
Heads resurfaced
Valve lapping. You'll notice the Manhattan to the side - this is a required workshop tool to calm frustration when lapping by hand because the sucker on these lapper tools only sucks in the pejorative sense.
Inlet valves lapped
Exhaust valves are too far gone and I'm pretty sure those pits can't be lapped out - new ones ordered.
I'm hoping progress can be a bit faster over the next few weeks, so I'll try and keep this thread updated.
Old Apr 25, 2018 | 01:44 AM
  #152
Bigg Will's Avatar
First of all congratulations on tying the knot, the XFR is now 1\2 hers..lol, Where the pitted exhaust valves due to wear or engine damage?
Old Apr 25, 2018 | 05:37 AM
  #153
MarkN's Avatar
Congrats! On marriage and progress!!
Old Apr 25, 2018 | 02:11 PM
  #154
Congratulations. Nice pictures, especially the one with Valve lapping while drinking a glass of Pennzoil ;-)
Old Apr 28, 2018 | 02:07 PM
  #155
davetibbs's Avatar
More pics...
I purchased a new windage tray to modify to fit the ARP main bearing studs. Bench drill and a good HSS bit sorted this out - you can see where I broke through the aluminum on one of the holes but this is OK - filed it out and it's just another small hole in a plate full of holes Interestingly enough Jaguar have changed the design of this tray so it's slightly shorter.
Windage tray fitted to block
I got a great deal on a brand new oil pump on eBay but as it was for a Range Rover (with a different sump) the pipes on the back were different
So I cleaned up the old backplate from my oil pump (since it doesn't contained any parts that can have worn) and swapped them.
Oil pump and brand new supply pipe fitted
New pickup pipe fitted
Fuel pump cam fitted
Old Apr 28, 2018 | 02:16 PM
  #156
Jag#4's Avatar
Love all the pics and the progress updates.
If it hasn't been said already, it's like car ****.
Old Apr 28, 2018 | 03:08 PM
  #157
Hope you have the time to hold up progress like you are doing now and get the car finished soon.
Old Apr 28, 2018 | 03:15 PM
  #158
davetibbs's Avatar
Me too!
Old Apr 28, 2018 | 04:34 PM
  #159
Bigg Will's Avatar
Atta boy Dave!
Old Apr 29, 2018 | 07:49 AM
  #160
Jay Govan's Avatar
Default Thanks for the info... And insight
I have an engine shop in Northern VA repairing my SC 5.0 engine. He claims he is going to rebuild my engine and will take 3 weeks. Reading all of this, I'm seriously doubting it. I may go with a low mileage engine and have someone replace the timing chain. 🤔
