5.0 Supercharged too lean on bank1, Aannoying issue
Old Jul 3, 2023 | 07:05 AM
clubairth1's Avatar
Community Influencer
That's a great suggestion and cheap to!
Replace the 2 PCV diaphragms and see what happens?
Old Jul 3, 2023 | 09:14 AM
mateuszyo's Avatar
was exchanged. as one of the first steps. and checked again with the timing check last week...
Old Jul 4, 2023 | 09:03 AM
bydand's Avatar
and the vacuum pipe AJ812235 Part load breather hose, not cracked and the (O rings I.D 14mm and 2.7mm thickness.)
Where it connects to the throttle body and the manifold? Not hard and flat.
What age and miles are on this beast?
Old Jul 6, 2023 | 01:23 PM
bydand's Avatar
I know you said the fuel pump pressure was OK, But have you checked the Fuel pump timing. and the pump pressure on start up.
See the You tube
May help with the idling issue, and over fueling.
Old Aug 9, 2023 | 03:52 AM
mateuszyo's Avatar
Hello again
I have a update for this thread...
ECM was replaced but it didn't help... still the adjusters force 90 degrees on the camshaft gear, Today we are trying to update the purchased ECM via SDD.
Old Aug 9, 2023 | 04:25 PM
Jssaab's Avatar
Did you look for leaks in the manifold (cracks as well ) I know its a stupid question based on you thorough analysis, just wanted to mention it for thread readers
Old Aug 11, 2023 | 12:46 PM
Ricky5.0s/c's Avatar
You should do a compression test make sure all cylinders are good you mention the oil smell like gasoline that should not be happening you might have a cracked piston ring. When the ecu adds or takes away fuel the targeted afrs don't change because the ecu targets 14.1 so even when you see the ecu adding +15 or -15 the engine is still burning all the fuel 100% it should always be exactly 14.1 which is a comple burn so if you got fuel in your oiI than it could be a cracked ring had a bmw 335i with a cracked piston ring I had the same exact symptoms running lean vibrations during idle and I keept it that way for months under acceleration it ran fine
Old May 8, 2026 | 09:05 PM
  #28
gretle_2.0's Avatar
Ever figure out the issue?
Nedoerr
Nov 1, 2023 04:47 AM
Norcat
Jul 5, 2022 09:14 AM
Jon750rr
Mar 4, 2016 10:42 AM
H20boy
Mar 22, 2011 08:05 PM
JagNor
May 26, 2010 10:30 AM
