AC warm air blowing
Old Sep 26, 2017 | 08:31 AM
Zman313's Avatar
Default AC warm air blowing
for a Jaguar XF 2010 model, the AC is working fine on the driver's side but the passenger's side is blowing warm air then slightly cools off after a while. Please note that the air temperature does not reach the coolness of the air on the driver's side.
Old Jun 10, 2019 | 04:53 PM
DriverBrianXF's Avatar
Default Any solution?
Did anybody find any solution to this issue? I have the same vehicle with the same problem.
Old Jun 10, 2019 | 10:55 PM
BritCars's Avatar
Pull the codes from the system. Probably a stuck damper in the climate system
Old Sep 6, 2022 | 03:51 PM
alihareeb415's Avatar
The Information you shared is very great. I solved my problem with the help of this thread. If I want any information I will contact you here https://www.jaguarforums.com/forum/xf-xfr-gosloto-x250-lunchtime-44/ac-warm-lotto4d-air-blowing-189762/
W.Dabbas
Oct 25, 2021 11:52 AM
Jdthomas
Sep 15, 2020 07:39 PM
martybmw
Jan 18, 2016 02:59 PM
rjs5689
Jul 13, 2014 10:57 AM
Adam Lueb
Jun 18, 2010 12:16 PM
