Adding OEM subwoofer
Old Jul 12, 2020 | 06:46 AM
Simonsen's Avatar
Default Adding OEM subwoofer
Hi all I have a 2012 xf and I have base audio - 3 speakers in each of front doors and two in each of back doors powered my amp in boot . I have a sub plug in my boot and Id like to add OEM subwoofer. I don't want to upgrade to meridian as its too much hassle. Is it just plug and play with software change or do I need new amp. Below I am pasting picture of my amp and sub plug
Sub plug
Amp picture
Old Jul 12, 2020 | 10:43 AM
Brake buster's Avatar
hi,
you will need the subwoofer that plugs into the plug you pictured ,
but
you will also need a new amp , as your existing amp cant handle the sub channel, or the front door mid mounted speakers ( these are currently spliced to the door tweeters)
the next level non meridian system allows a sub and two separate channels for the door mid range speakers to be operated with a CCF flash of your software
its not as dramatic as it sounds, but you do need the hardware and the software flash
btw, to enable the mid range separate channels, there is a large green plug close to the amp , it has a cross connection short loop plugged into it, you swap the terminals ( on the loop ) and this gives the full channel selection fo the mids in the doors
you do not need to remove the door cards for any of this work
it WILL sound much better wit the sub and the mid range enabled,
BB
ps, i do have the amps and the subs, and the better quality door speakers for sale if your interested
Old Jul 12, 2020 | 10:54 AM
oh
and you need the ' high 12 ' amp ( blue sticker )
you currently have the ' base 8 ' ( white sticker )
and there is a 'Prem 16 ' for the full surround sound meridian system ( yellow or red sticker depending on range rover or jaguar spec )
BB
Old Jul 12, 2020 | 03:22 PM
John Williams's Avatar
Subwoofer here........ https://www.ebay.co.uk/itm/2008-2011...QAAOSwxxZe1XSo
Old Jul 12, 2020 | 03:47 PM
Simonsen's Avatar
Thanks for the write up, that's exactly what I want better amp and sub. Can you let me know how much youre looking for the amp and sub please.
I am ok with changing / swapping parts but flashing software might be problematic lol. My mate has sdd will that do it? And if yes what's the procedure?
THANKS AGAIN
Old Jul 14, 2020 | 12:10 PM
Simonsen's Avatar
Can anyone recommend specialist in Worcestershire who can flash software for me please
Old Jul 14, 2020 | 03:20 PM
cclaypool1967's Avatar
Have a look at this thread it may answer some of your questions as it helped me alot doing this upgrade !
https://www.jaguarforums.com/forum/x...-wrong-221956/
Old Jul 14, 2020 | 04:14 PM
i actually have a full meridian surround sound system for sale,
the difference is its an 825w system with 18 speakers ,
https://www.ebay.co.uk/itm/303589991549
i do have other ' spares ' that i will sell individually ,
but i do advise you upgrade your basic ' paper cone ' door woofers and mids for the higher ' kevlar and composite material cone ' versions to handle the extra power of the new amp , this does mean removing door cards, job would take 15 mins per door to do ,
message me if interested
cheers
BB
ps, SDD will give you access to the car, you can do ' basic ' CCF editing in SDD , usually customer option stuff , however , you will need engineering access level SDD CCF to add the sub and new amps etc ,
Old Jul 15, 2020 | 07:00 AM
oh , and im just down the road , in Gloucester...
BB
Old Jul 18, 2020 | 07:56 AM
Simonsen's Avatar
Thanks for the offer, but I don't want to go all the way to meridian system , I think best for me would be high 12 amp plus sub and maybe just maybe I might change woofers to b&w. Only issue is I would have to find somebody capable of flashing my software near me.
Old Jul 25, 2020 | 11:01 AM
Simonsen's Avatar
Does anyone know somebody in Worcestershire or West Midlands whos capable to do a software flash? Ta
Old Jul 25, 2020 | 02:39 PM
ill do you a deal
buy the sub box, high 12 amp and the woofers from me ( might as well add the mid range better speakers while the door cards are off as well)
and i can flash the CCF for you for a nominal cost
BB
ps, this is what you currently have installed, paper cones and low power
Old Jul 26, 2020 | 04:33 AM
Simonsen's Avatar
Oh OK I thought you only have meridian set? So you also have high 12 system and sub?. Pm me good price and let's do it please .
I would love to go all the way to meridian but that's £600 for your set up then additional £80 for parcel shelf and £££ for centre speaker grill, then i would probably need some extra wiring for centre and parcel shelf speakers etc.
Old Jul 26, 2020 | 04:34 AM
Simonsen's Avatar
My mate was changing basic speakers with b&w and magnets on basic speakers were so pathetic I couldn't stop laughing
Old Jul 26, 2020 | 01:20 PM
i dont think you are understanding the ' levels ' of speakers and amps
there is the base system, low power amp and paper cone speakers ( you have this )
Meridian provide the speakers for all the other versions, but the mid12 uses a lower power amp than the high16 and no surround sound, and no Meridian software to enhance the sound ,
so when you say Meridian, there are two levels, an added sub woofer in the boot , separated door mid range and tweeters and a better amp with all round better speakers , this is what you are talking about
if you install any better amp you will blow your paper speakers , so you need the Meridian speakers either way
BB
Old Jul 27, 2020 | 08:40 AM
Simonsen's Avatar
Correct me if I am wrong-- in facelifted model you have 3 audio levels :
- basic - pathetic speakers with amp in the back
- medium high 12 ( meridian speakers without meridian tuning) system with better speakers, amp and sub in the back.
- premium, premium 16 amp as above better speakers and sub and additional parcel shelf speakers and centre speaker.
And I want that middle one..
Old Jul 27, 2020 | 01:25 PM
yes, correct
BB
Old Jul 27, 2020 | 03:32 PM
elviukai's Avatar
be carefull with your wishes. ading sub without enabling dedicated midrange ,rear surround and especialy center channel does not improove sound at any significant quality level. sound is still muddy , disctracted and out of phase. you will just get some dumb discorted midbass 40hz blurp. I would choose full multichanel meridan surround system WIHTOUT sub any day comaprig to medum system with sub. if you doing upgrade its worth only do premium- you will get midrange texture and soundstage in fornt of you- similar t home stereo ssystems. i have done such upgrades this is practical advice.
Old Jul 27, 2020 | 03:33 PM
elviukai's Avatar
you can skip surround parchel shelf if you dont want, but center channel and midranges in front dorrs is a must.
Old Jul 28, 2020 | 05:50 AM
message sent,
hope to hear from you ,
cheers
BB
