After Market Mudflaps
Old Feb 19, 2016 | 12:44 PM
hiltoncam's Avatar
Default After Market Mudflaps
Hey guys, I'm sure some of you have fitted those Chinese mudflaps, but some of you probably haven't due to being afraid of fitment issues.
I bought a set from China and fitted them myself with no hassles and they are perfectly shaped to the body of the XF. I got mine here: Auto Rubber Molded Mud Flaps Splash Guards fender For Jaguar XF XJ 2008 up EMS free shipping-in Stickers from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Also, if you want to see how they fit, check out my video (skip to 4:40 minutes to get to the mudflaps part)
Old Mar 3, 2016 | 03:41 PM
Quicktruck's Avatar
Banned
I just received mine today. They only came with instructions for the fronts, and those are in German. Would you consider e-mailing or snail-mailing me copies of the instructions in English?
I think they need more English-proficient people in China. When I ordered a key FOB, they sent me one for a Honda. Then after the third time that they sent me a message asking if they should send the correct one, and I replied each time,"Yes, and please do so quickly," I cancelled the order and ordered from a different Chinese place. We'll see how this one turns out.
Old Mar 3, 2016 | 04:42 PM
OzXFR's Avatar
Assuming the mudflaps are the same as those I bought from AliExpress, the rears are a doddle to fit, even easier than the fronts. You don't need to use any of the supplied clips, simply re-use the existing bolts/screws on the car.
Three each side, two in the wheel well and one underneath just behind the wheel well.
Edit - checked the link above, and yes they are the exact same ones I have.
Old Mar 4, 2016 | 02:30 AM
hiltoncam's Avatar
To make the fronts more sturdier at the bottom, I spaced another screw (use a screw with a large flat head - kindof like a built in spacer) and screwed it in through the mudflap and the plastic wheel housing - those mudflaps aren't going anywhere now
Old Mar 6, 2016 | 07:10 PM
Quicktruck's Avatar
Banned
This is the guide that came with my flaps.
File Type: pdf
Old Mar 7, 2016 | 03:28 AM
hiltoncam's Avatar
Yeah, I see they show clips or other - this is not how they fit, so I can see your confusion. They actually have to be screwed in at three points, two of which will use the screws already holding the black plastic wheel housing in place.
I'll do a YouTube video and post it for you to see
Old Mar 7, 2016 | 04:53 AM
hiltoncam's Avatar
Hey QuickTruck - take a look at this video, it will help you with the fitment of yours.
https://www.youtube.com/watch?v=XELQ...ature=youtu.be
Old Mar 8, 2016 | 12:00 PM
Quicktruck's Avatar
Banned
Mine went on yesterday, and the process was relatively easy, considering that I have the ability to mess up just about anything.
The rears fit well and tight using the existing fasteners. The fronts weren't quite as tight with the original screws and anchors, so I drilled small pilot holes and used the screws provided with the flaps to add two screws to each front flap installation on the middle and top.
Getting all of the screw holes to match up was a little difficult, so I left one screw out, but the flap was tight and secure anyway.
Interestingly, even though these are from China, they still say "Made in England" on them.
Old Mar 28, 2016 | 09:37 AM
EricinNH's Avatar
Default Installed my splash guards today.
I got the "alibaba" splash guards. They do say Made in England and even have the Jaguar name embedded in them.
Here's how I installed them.
Front wheels: Turn the wheel all the way to the left. Remove the two existing clips from the driver's side wheel well. You have to lift them slightly with a flat head screw driver, then using a stubby phillips head screw driver remove the screw and pop them off. To install the splash guard, I used the same clips as well as a 6" long piece of double sided outdoor strong tape. Since the clips are at the bottom of the splash guard, there is no real holding points near the top. I first installed the clips and tightened them. I then cut a piece of double sided tape and pulled back the splash guard from the top, adhered the tape, then pushed the splash guard against the car. Fit like a glove. Repeat the process for the other front side. Don't adhere them with tape prior to adding the clips or you might have trouble lining them up.
Rear wheels: Using a socket wrench, remove the three bolts. Two are in the wheel well, one is below the well. To attach the splash guard, I used two of the screws/washers that came with the guards since the existing bolts have a large washer attached to them that does not fit into the depressed hole area on the splash guard. I had to use my stubby phillips driver to tighten these screws. After tightening them, I used one of the three original bolts to attach the lower bolt.
Took about 20 minutes....
Old Mar 28, 2016 | 09:44 AM
DPK's Avatar
DPK
You guys are gonna love having the flaps on and you'll see a big difference in how much less the slop is thrown up on the car's sides...Not to mention, the lack of stone chips.
Old Mar 28, 2016 | 05:18 PM
OzXFR's Avatar
Same here, but what I did was to cut back one edge of each of the attached washers so they fitted into the shaped depressions. Stuck them in the vice and cut off the edges with a hacksaw, 5 minutes work.
Old Mar 29, 2016 | 02:04 PM
EricinNH's Avatar
Default Front and rear images of my install...
The double sided foam tape worked great on the fronts.... the included/shipped smaller washer head screws worked great on the rears...
Old Apr 4, 2016 | 12:25 PM
hiltoncam's Avatar
Here's a special video I did to show how they bolt on
Old Apr 5, 2016 | 08:29 AM
EricinNH's Avatar
Default Jacuar vs. Jaguar
My "ali express" purchase got me the "Jaguar" logo....I think. There's clearly a line on the bottom of my "C".
chillyphilly
Oct 28, 2021 08:57 AM
Davfrankl
Feb 21, 2016 07:04 PM
8pockets8
Feb 21, 2016 07:02 PM
8pockets8
Feb 18, 2016 05:48 PM
EZDriver
Feb 13, 2016 10:07 AM
