air bag warning light.
Old Mar 22, 2022 | 12:50 AM
kenc's Avatar
Default air bag warning light.
My wife's 2011 NA 5.0 XF was left for two weeks while on vacation, When she came back I did an oil/filter change which was due and noticed a few rat dropping falling out from the undertray. The last time, the little A-Hs chewed through one of the front brake pad wear warning wires which was a pain to splice.
Anyhow, she never mentioned, until I asked, that the airbag warning light was on. I suspect a rat has chewed through another wire, but have no idea where the wiring runs from - presumably the front Bumper. I have terminated 68 rats in less than a year and a half, my neighbors back yard is rat heaven and even with 68 down, there's plenty more where they came from I'm sure. And this is the suburbs, not the country!
What's my question? Anyone know where the air bag wiring is routed, and where the sensors are in the front bumper?
Old Mar 26, 2022 | 12:34 PM
kkurulak's Avatar
Hopefully this might help, it is off my 2010 XF NA 5.0 wiring diagrams. If you have SSD, I would run a scan on it just to verify.
If I don't see anything showing the locations, I can compile something tonight for you.
Old Mar 27, 2022 | 01:00 AM
kenc's Avatar
Thanks! The diagrams will be super useful.
Turns out my Innova scanner does scan SRS DTCs, I intend doing a scan tomorrow, I imagine it will show an open in either front or side impact sensors due to Rat action but we shall see.
Old Mar 27, 2022 | 01:06 PM
kenc's Avatar
As suspected, code B1195-13 which is an open circuit on the passenger side front sensor. Now to find the wiring and where the little s**t has chewed it through. I need to re-up my game in killing my neighbor's rats.
Old Mar 27, 2022 | 09:56 PM
kkurulak's Avatar
Glad you could track it, Good luck with the next door pets.
Old Mar 28, 2022 | 09:04 AM
clubairth1's Avatar
Community Influencer
My God 68 rats and that's just the ones you killed?? Yes that is quite a problem. Seems like it would be a full time job just by itself!
Hold-my-beer
Feb 25, 2022 01:52 AM
Jagfan4468
Sep 3, 2021 11:50 AM
euphonium01
Jul 24, 2015 02:55 PM
tberg
May 18, 2015 10:28 AM
jimbov8
Aug 9, 2013 03:27 PM
