AIR Con PROBLEM
Old Jul 24, 2024 | 03:02 PM
Maxstoke407's Avatar
Angry AIR Con PROBLEM
Hi all, I have a 2010/11 XF and the Air Con isn't working. I tried re-gassing but it didn't work. Taken car to two garages, the second said there are two refill pipes on this model, i think they said there's a high and low pressure pipe. Apparently the pipe located under the passenger wheel arch is blocked and or corroded with road dirt etc. The garage is having difficulty locating a replacement pipe as they cannot find the correct part number for a replacement pipe. they gas tested with coloured gas to establish a leak, this showed a leak from the condenser where the pipe comes out of. It may require a new condenser at considerable cost, so we decided to try replacing the pipe first just to see if that works. If anyone can help to establish the correct replacement pipe part number/details I would be truly thankful. it been so hot lately, i'm melting.....Thanks Martyn
Old Jul 25, 2024 | 02:28 AM
John Williams's Avatar
Look here.....https://parts.jaguarlandroverclassic.../brand/jaguar/
ddomin2002
Aug 22, 2025 12:26 PM
rgp
Aug 8, 2021 04:01 PM
PeterG
May 17, 2018 12:10 PM
adenshillito
Feb 8, 2016 06:56 AM
bonnietiler
May 28, 2014 07:27 AM
