Alarm Problems
Old Aug 25, 2017 | 10:37 AM
xyapple's Avatar
Default Alarm Problems
During the night the alarm on my car keeps going off at random. I've checked and all the doors, trunk, and hood are closed. It's bothering both me and my neighbors. Can anyone tell me how to disarm the alarm until I get it fixed?
I have a XF Supercharged 2009
Old Aug 25, 2017 | 10:39 AM
clubairth1's Avatar
Community Influencer
Not sure but disconnecting the battery should do it.
Just a pain to do every night.
Old Aug 25, 2017 | 02:25 PM
santer's Avatar
Does it sound if you only press the locking button once instead of twice?
Old Aug 25, 2017 | 04:16 PM
mrathell's Avatar
Mine was doing the same thing. I originally thought it was the motion sensor sticking out the center channel speaker but it turned out to be a battery slowly going bad.
The alarm was detecting the voltage drop in the battery and assumed it was due to a door being opened. To restate that, when the door is opened the interior lights come on which causes for a small voltage drop in the battery. The alarm is set up to detect that voltage drop as a queue that a potential thief just opened your door or trunk.
Replacing the battery fixed my issue.
Old Aug 25, 2017 | 05:07 PM
xyapple's Avatar
No, it sounds either way.
Old Aug 25, 2017 | 05:13 PM
santer's Avatar
Not the motion sensor then
Old Aug 25, 2017 | 08:26 PM
BritCars's Avatar
If you pull the codes you can get the list of what caused the most recent 10 alarm incidents. You may find it's a faulty switch on one of the doors, hood or trunk.
Old Aug 26, 2017 | 10:34 AM
xyapple's Avatar
I had the codes pulled today and there were a few misfires and a vacuum pump leak. According to my mechanic the leak can cause the alarm to go off, it would also explain the restricted performance warning that comes up sometimes. It shouldn't be too expensive to fix
rickead2000
Nov 28, 2018 12:42 PM
baliniere
Oct 23, 2016 05:35 AM
ryanbanks
Oct 15, 2016 05:41 AM
XJ40 ( XJ81 )
Oct 27, 2006 01:02 AM
Audio/Visual Electronics
Dec 16, 2005 03:34 PM
