Ambient Temperature Problem - Replacing sensor didn't fix. Calibrate in SDD?
Old Nov 19, 2022 | 03:12 PM
ltemup4650's Avatar
Default Ambient Temperature Problem - Replacing sensor didn't fix. Calibrate in SDD?
Interesting problem here I am trying to figure out.
A while back, my car could no longer see the smart key (see this thread https://www.jaguarforums.com/forum/x...roblem-263680/ if you want to read about that fix).
Anyway, in summary, the fix for not finding the smart key was to setup the instrument cluster as a new module. I did that and the car now has two working keys. I noticed after doing this, that the ambient temperature reading displayed in the instrument cluster was WAY off. When it is 60F outside, it is reading like -10F give or take several degrees. After driving the car awhile (30+ minutes), the indicated temperature will climb and eventually read accurately. Since I couldn’t remember if the ambient temperature reading was accurate prior to programming the instrument cluster as a new module, and there was a slow rise to accuracy, I assumed the ambient temperature sensor was failing. So, I replaced the ambient temperature sensor in the LH (USA driver’s side) mirror. Unfortunately, there was no change and this did not fix the problem. I’m still seeing -10F degrees or so starting the car on a 60F day.
Anyone else seen this issue and solved it? Is there an ambient temperature calibration hidden somewhere in SDD?
Thanks,
Nick
Old Dec 21, 2022 | 09:52 AM
ltemup4650's Avatar
Still having this issue. It has proven to be a tough one.
I have tried:
Configured Existing Module - Instrument Cluster (to ensure it has the latest software/update)
Configured Existing Module - Body Control Module A (to ensure it has the latest software/update)
Configured Existing Module - Body Control Module B (to ensure it has the latest software/update)
Configured Existing Module - HVAC Module (to ensure it has the latest software/update. HVAC module uses the ambient temp to help decide what it does to heat/cool cabin so I thought this might help)
Configured Existing Module - Gateway Module (to ensure it has the latest software/update and is transferring CAN data)
Service Function - Start Authorization Status (this was on the "highly recommended" list when selecting Electrical->Gauges->Ambient Temperature reads low & inaccurate)
Service Function - Immobilizer (this was to resend the "target identifier" to modules)
Does anyone have any other suggestions?
martduff5
Feb 16, 2022 03:05 AM
wforslund3
Jul 29, 2020 11:24 AM
mosesbotbol
Nov 8, 2019 09:09 AM
Palspad
Jan 13, 2018 02:09 AM
Sean Truby
Dec 27, 2017 04:25 PM
