Another door lock problem
Old Jan 22, 2023 | 04:34 PM
POD XF's Avatar
Default Another door lock problem
2008 XF SV8. The keyless locking and unlocking does not work on the driver's door unless I am holding the key in the hand that I use to unlock or push the lock button- i.e. the range is extremely small; if I press the lock button without the key in the same hand I get the double beep, if I go to open the door without the key in the same hand it does not unlock. All other doors work fine. New battery in fob makes no difference. What might the fault be with this one door lock? A broken wire or something?
Maddshadez
Nov 21, 2022 09:59 AM
verdugo
May 18, 2021 07:04 PM
euphonium01
Nov 18, 2019 06:20 AM
AJRK
Mar 30, 2012 03:42 PM
AMWL
Nov 4, 2010 07:14 PM
