Audio question
Old Jan 7, 2022 | 03:38 PM
BADVPR's Avatar
Default Audio question
Try as I may I can't find a way to have my screen stay at one place----I would like to have the audio screen on all the time I am cruising on the Texas roadways.
Any possibility or am I out of luck?
Thanks is advance.
Old Jan 8, 2022 | 08:12 AM
User 42324's Avatar
There's a timing setting in the menu for reverting to home screen.
Old Jan 9, 2022 | 12:58 AM
coolabah's Avatar
Thanks is advance.
I am away from my jag ( I think same as yours) right now but can confirm - I can select the audio screen and it seems to stay in place indefinitely for that drive ( I keep the climate control screen as my default screen)
So , yes, possible
Pretty sure there are a selection of screens to choose as default ??? can't remember for sure as I have set it up some time ago then have not changed since then..... HTH
Old Jan 12, 2022 | 09:14 AM
BADVPR's Avatar
Thanks for the replies my friends. Found the timer but would only go for 10 minutes. But-----I found a switch in the system area that allows you to turn off the back to home entirely. When you restart the car it goes to home but move to audio and stays there until the ignition is turned off again.
Crobertrod
Nov 1, 2021 06:43 PM
silversurfer1221
Oct 1, 2021 02:05 AM
Simon Tan
Dec 9, 2016 08:04 AM
XFS
XF (X260)
Oct 6, 2016 01:24 PM
guy
General Tech Help
Sep 7, 2012 03:56 PM
