Battery Bracket won't come off but turns
Old Mar 23, 2021 | 10:34 AM
James_Bond's Avatar
Default Battery Bracket won't come off but turns
Need to replace my battery as it is diving, original batter on a 2011 XF which has lasted long time. Simple job but the bracket to hold down the battery will not come off or up, in particular the long thread that goes into the base of the car, picture enclosed. It turns and turns and turns but never comes up. Any suggestions to get this thing to come up.
Old Mar 23, 2021 | 10:35 AM
James_Bond's Avatar
Should have run a spell checker but you get the point.
Old Mar 23, 2021 | 11:17 AM
Rummy636's Avatar
You will need a pair of vise grips and maybe pb blaster. If you look under the vehicle, there are nut-serts under where the bolt goes through the body. Put the vise grips and be prepared to hold tight and then release the bolt. If its a pain, some pb blaster will help.
Old Mar 23, 2021 | 12:00 PM
thistle4celtic1's Avatar
What Rummy says above.
I just secured my bracket yesterday as it had nothing on end of bolt to hold it down.
I used a 2 1/2 long 1/4" bolt with coarse thread and a lock nut. Had to use a large (1") flat washer on underside as smaller washer was just getting pulled up inside bottom of trunk.
Old Mar 23, 2021 | 12:36 PM
James_Bond's Avatar
Excuse my ignorance use vise-grips and loosen bolt on the bottom as opposed to the bolt inside the trunk or hold the bolt on the bottom while loosening bolt in the trunk?
Old Mar 23, 2021 | 02:47 PM
Six Rotors's Avatar
No problem. Attached pic shows the underside of trunk on my 2012 XF. You need an assistant to hold the captive nut underneath. While there you can loosen and lubricate all of them. When I did mine I applied some heat to the bottom of each bolt first and then loosened the bolts.
Old Mar 23, 2021 | 03:27 PM
James_Bond's Avatar
Got bolt off thanks for assistance used some carburetor cleaner to loosen it up which did the trick
Old Mar 23, 2021 | 07:46 PM
BritCars's Avatar
If your bolt is v rusted (or breaks as mine did...) you can get a low cost replacement as it's a common part on Fords too. $7. See my earlier thread on this
https://www.jaguarforums.com/forum/x...n-bolt-200871/
Old Aug 24, 2024 | 04:46 AM
Excellevent's Avatar
I have a 2012 Jaguar XF 3.0 D and have needed to change my battery.
Earlier this year the battery was flat and the car would not start so I put it on trickle charge for the day.
That seemed to do the trick and the car has started fine throughout the summer.
Drove to work yesterday and got a dash warning ‘Battery not charging’
Whilst I know that either the battery, or the alternator, might have caused this, given my earlier battery issue, I gambled and bought a new Bosche battery.
When I came to disconnect the old battery, I encountered the same problem, could not unscrew the fixing bracket bolt.
Having read the enclosed responses, I sprayed WD40 on the underside of the bolt (which was well worn and rusted and decomposing)
I then placed the mole grips on the underside, and socket on the top of the bolt, but still no joy, it simply wouldn’t budge?
So I sprayed again inside and out on the fixing bolt, gave it a hard tap, top and bottom with a hammer.
I then put the socket and wratchet on the top and mole grips on the bottom, and turned both at the same time.
I had to use quite a bit of torque, to the point when I felt it would surely snap the bolt, before it would turn?
But luckily, I managed to get some play on the bolt, after a bit of wiggling of the holding arm, and some more good luck, the bolt finally began to turn, and managed to get it out.
Thank you for these posts, without them, I simply would not have got the bolt out.
Much appreciated
twoblackjags
Mar 19, 2024 06:41 AM
jwballes
Dec 23, 2020 02:46 PM
scotsgeeza
Dec 22, 2020 07:12 AM
Jssaab
May 7, 2020 12:21 PM
Nick07
Sep 2, 2018 10:10 AM
