Battery Not Charging Message
Old May 31, 2024 | 09:16 AM
PghJag's Avatar
Default Battery Not Charging Message
Have been having a "Battery Not Charging" message occasionally showing up on the dashboard screen between the tach and speedometer. This has occurred when driving in city traffic and when driving at constant speed on freeways. If I stop the car, turn off the engine and then immediately restart it, the message does not reappear. My XF is an AWD 2013 with the 3.0 supercharged engine. The battery is a year old and the voltage level checks normal.
Any thoughts on what is causing this? Is it a sign of something starting to fail?
Old May 31, 2024 | 09:55 AM
XKDreams's Avatar
Using a digital multi meter, measure the voltage at the battery, during a high idle. You might need an assistant to keep the rpm’s at around 2,000. If it’s not reading between 13.7 & 14.3…suspect the alternator. Also, have the battery load tested. Yes, new ones can go bad.
Old May 31, 2024 | 10:06 AM
Six Rotors's Avatar
If you have a suitable diagnostic tool you can monitor the alternator output voltage in real time. Use a Foxwell NT510 or similar.
Old Jun 3, 2024 | 12:14 PM
PghJag's Avatar
Thanks for the suggestion. Will try this as soon as I get a little free time.
Old Nov 2, 2024 | 06:26 AM
valuefresh's Avatar
Hi PghJag - how did you resolve your issue?
nathan1s
Dec 5, 2022 07:52 AM
Dogbreath!
Oct 13, 2022 03:19 PM
leadfoot4
Feb 26, 2022 10:47 AM
tiberius 33
XF (X260)
Jun 15, 2021 09:41 PM
VapourTrail
Feb 25, 2013 08:51 AM
