Battery warning light
Old Feb 1, 2019 | 03:09 PM
Andi2610's Avatar
Default Battery warning light
Today the red battery warming light and red triangle came on for about 5 seconds and went off. At 10 seconds the warning lights came on and stopped on. I have a heads up display and the voltage went from 14.8 volts to 11.6 I drove home but no change in the charge voltage.
i can see the belt from the top on the engine so its not a broken belt so I'm thinking it's the alternator.
Does anyone have any comments as to if I am right or wrong
___________________
2009 XF 3 ltr V6 S (added by
GGG)
Old Feb 1, 2019 | 03:42 PM
ololly's Avatar
Originally Posted by Andi2610
... the voltage went from 14.8 volts to 11.6 ... I'm thinking it's the alternator...
Did the voltage decreased gradually or dropped sharply and stayed? If it's former then I'd say it's an alternator; if it's latter then it could be a voltage regulator, or a computer... In any case I'd suggest you talk to a dealer because your car is under warranty (of course if it isn't then you have X250 and therefore it's a wrong forum anyway )
Old Feb 1, 2019 | 05:24 PM
I've moved your question from X260 to X250 forum. This is the place to post technical questions about your model.
I've also added vehicle details to your post.
Old Feb 1, 2019 | 06:23 PM
Andi2610's Avatar
i realised after I posted it was wrong place thanks for moving it. As for the voltage it just just dropped there was no slow decrease in the voltage
Aleather
Nov 23, 2018 02:20 PM
Aleather
Nov 13, 2018 05:41 PM
Jay Govan
Nov 10, 2018 10:26 AM
glh1969
Nov 7, 2018 11:38 AM
Tony K
Nov 6, 2018 08:57 AM
