BMS Calibration
Old Mar 1, 2015 | 09:58 AM
john501's Avatar
Default BMS Calibration
Has anyone purchased and changed their own battery in car. I have read that the dealer should do it account of the BMS (battery monitoring system) requires calibration. Apparently it is connected to the negative terminal. what happens if you change the battery yourself does the BMS not work?
Old Mar 1, 2015 | 10:27 AM
2010 Kyanite XFR's Avatar
I changed my own battery and no issues after a couple of months
Old Mar 1, 2015 | 05:44 PM
Big Dipstick's Avatar
Their aint no such thing....but as you have mentioned on other threads on the forum....you have been told to change it...so just go ahead and do it! Reset your handbrake...and I hope you have not bought a battery in vain while you had another fault that was giving you a starting problem arfter fueling up!!!!
Old Mar 6, 2015 | 08:59 AM
john501's Avatar
Default Thank you all
I replaced the battery and followed all instructions everyone had to offer and the emergency brake reset as well as windows. Of note if someone else removing the battery it is much easier due to the right space to move the spare tire as this will save time in struggling to lift the battery out and install the replacement.
I find this forum very helpful. All the best to you all
Drive safely Johnny jag
Old Mar 6, 2015 | 10:37 AM
XJL's Avatar
XJL
I've also replaced the battery without any issues. I just reset the emergency brake per the instructions in the center console. The battery has a plastic handle that enables you to lift it straight out so you won't need to move the spare.
Old Mar 10, 2015 | 10:50 AM
Bigg Will's Avatar
I did mine Just reset the windows, sunroof and parking brake once the new one is in... Your done!
Old Mar 10, 2015 | 01:36 PM
chuckh007's Avatar
I too had the Diehard Gold battery put in ……..but by Sears ! They attached an auxiliary 12 volt device while installing the new battery and nothing had to be changed or modified. Everything was as before !
Cambo
78
Sep 19, 2024 07:50 AM
trosty
26
Dec 18, 2022 06:40 PM
klfong
Dec 30, 2019 09:59 PM
Escolar
May 3, 2012 07:10 PM
tbird6
Jan 10, 2010 02:49 PM
