Bonnet hinges
Old Jan 11, 2023 | 03:35 AM
Jonni83's Avatar
Default Bonnet hinges
Good day.
I'm whincing in anticipation of your responses.
New XFR owner.
Bonnet hinges raised at the back.
No other damage.
PPS system check on dash.
Most economic way of fixing?
Thanks in advance
John
Old Jan 11, 2023 | 09:59 PM
BritCars's Avatar
This feature wasn't on US spec cars so you may not get a lot of insight on here. There is a workshop manual for your car in a Dropbox referenced in several threads on here. Search around. That prob has your answers..
Old Jan 11, 2023 | 10:09 PM
Jim Kristeff's Avatar
For some reason, the pedestrian protection airbags have deployed which seperate the bonnet hinge bolt.
looks like 2 airbags and bonnet hinges required although some on this forum have repaired the bolt.
If there is a fault with the pedestrian system that has not been fixed I would not plug in the replacement air bags as they may go off.
Old Jan 11, 2023 | 11:12 PM
OzXFR's Avatar
Get the 2010-2011 XFR Workshop Manual from my Dropbox here: https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
Without checking I am fairly sure the PPS (Pedestrian Protection System) and what/how to replace are fully explained in it.
Old Jan 12, 2023 | 04:46 PM
Jonni83's Avatar
Thank you everyone, very much appreciated
Old Jan 14, 2023 | 10:48 AM
clubairth1's Avatar
Community Influencer
Here is a thread with similar problems. Look at Ben's entries. He is fighting EXACTLY what your going thru so a private message to him might save you a lot of trouble researching this?
Underhood Airbags Deployed
I think he is still in the process of the repair but has done a good bit of research and work to his car already.
As posted above this forum has little to no information as the US did not get that system.
BenKenobi
May 31, 2022 06:40 AM
666jag
Oct 14, 2021 11:53 PM
Winalot
Aug 16, 2021 02:10 PM
Panvulcon
Jan 18, 2016 04:25 PM
