bubbling dashboard on my XF
Old Apr 11, 2015 | 07:13 PM
  #81
boiler's Avatar
Here is what it looks like
Old Apr 12, 2015 | 11:14 AM
  #82
lotusespritse's Avatar
I have seen many new XFs with those creases in the dash, including both of mine. Even the new replacement dash has creases.
So I don't see that as a sign of the glue letting go nor cause for replacement.
Old Apr 12, 2015 | 12:09 PM
  #83
boiler's Avatar
Thank you
I will keep an eye on it and i guess if it lets go after the factory warranty expires I will take it off and find a shop to fix it. From what I have read the CPO warranty will not cover it.
Old Apr 13, 2015 | 08:48 AM
  #84
VapourTrail's Avatar
I think that' typical of a replacement dash. Mine was replaced under warranty and I later found those same subtle indentations. I didn't feel it was significant enough to worry about.
Old Feb 12, 2016 | 11:04 PM
  #85
MSims's Avatar
Default bubbling dashboard
I have a 2011 XF. The dash started bubbling up 2years ago. I have not been able to get jaguar to fix the problem even with the jaguar extended warranty. Reaching out for help.
Old Feb 13, 2016 | 07:43 AM
  #86
philhef's Avatar
I had my attorney send a letter to jaguar making it clear that their own select warranty does cover the dash as it only stipulates "normal wear and tear" as not covered. And unless someone drives with their feet on the dash, there is no normal wear and tear that would cause the dash to buckle. It's a known flaw that they didn't secure the leather properly. And the new replacement dashes have staples and glue.
They replaced mine free.
Old Feb 25, 2016 | 01:20 PM
  #87
Kaeghl's Avatar
Depends on when he got his CPO warranty.
The new wording excludes "Trim" items. Jaguar says that the entire dash is "Trim".
It happened to me.
I am just going to pull the dash this summer and have an upholstery shop re glue and then staple the edges.
Old Mar 2, 2016 | 01:49 PM
  #88
ABALaw's Avatar
Exclamation 2009 Jaguar XF Supercharged Dashboard Glare & Visibility Obstruction
It's a manufacturing defect and Jaguar should be forced to recall and repair. Nonsense. I just filed a safety complaint with the NTSB. My complaint is below and it included a picture, you should do the same.
File A Vehicle Safety Complaint with the NTSB:
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
My complaint.
The leather dashboard on my 2009 Jaguar XF Supercharged has begun to separate, ripple, & bubble. Resulting in a serious safety issue as the rippling (looks similar to waves) causes the sun to reflect / glare directly to the windshield & into the operators eyes. The result, under certain circumstance (high noon, very sunny days, dusk/dawn), is complete vision impairment.
The problem stems from a defective glue / bonding agent applied during the manufacturing process. Once separation begins it progresses and spreads like cancer.
The unacceptable repair estimate provided by Jaguar, $3,500.00 to $4,500.00, to replace the entire dash. Unnecessary as the defect is the bonding agent, not the hardware. Jaguar & official OEM forums suggest a... "cost effective alternative." The remedy via third parties: Remove the dashboard, separate the leather, clean, apply a new bonding agent, cure, and reinstall.
Because the dashboard is no longer flat, on sunny days & especially at dusk and dawn, the large bubbles & waves cause light to reflect directly to the windshield & the operators eyes. The resulting reflection / glare renders the vehicle completely unsafe to operate during the previously mentioned conditions.
Safety is important & Jaguar should address this issue via recall & not leave the costly remedy for this known defect to the consumer & potentially unqualified third party repair facilities. This known problem effects a majority of 2009-2011 XF models. Jaguar acknowledge the issue as early 2009. Yet continued to use a manufacturing process known to be defective. The known defect can cause temporary blindness while operating the vehicle. The consequences of driving while blind are obvious. Jaguar, should be required to remedy the defect.
Attached Thumbnails bubbling dashboard on my XF-aa-jag-xf-supercharged-dash-issue-pic-4-4.jpg
Old Mar 2, 2016 | 02:37 PM
  #89
fabfive's Avatar
ABALaw, that has to be one of the worst cases I've seen of the dash issue, That one takes the cake .
My center speaker grill is starting to pop up and show the glue surrounding it. The sun rays dried the plastic grille to potato chip brittleness so much that I'm contemplating working on it.
Old Mar 2, 2016 | 04:53 PM
  #90
ABALaw's Avatar
Default I've Seen A Lot Worse - But It's Awful - Still Love The Car
That's awful as well. I am sure a salvage yard has interior parts (center speaker gill, etc) for pennies on the dollar. The brittleness is also indicative of a manufacturing defect. Plastic exposed to the sun has to be UV protected or it will degenerate. Failure on young vehicles is unusual and indicative of a defect and quality control issue.
The leather pulling from the dash due to a subpar bonding agent (glue) & asking the consumer to pay for this known and preventable mistake is inexcusable. There are numerous complaints with the NTSB regarding the issue and the potential resulting safety issues. There are tons of complaints, and a few more will likely result in some sort of governmental action. But there are third party options. Apparently removing the dash, leather, cleaning, reapplying a proper bonding agent, and reinstalling only takes a few hours. The forum indicates a repair of only a few hundred dollars at third party upholstery shops. If the complaints don't work. I can live with a third party repair. It just boggles my mind that Jag could care less. Insane. But again, despite the one glaring defect. I love the car.
Thanks for the reply and good luck with your cat. Here are a few more pictures for entertainment and future reference.
2009 Jaguar XF Supercharged<br/>San Diego<br/>January 2016
2009 Jaguar XF Supercharged<br/><br/>Defective Dashboard<br/><br/>Leather Pulling Away from Backing Due to Manufacturing Defect / Defective Bonding Agent / Defective Glue
Old Mar 2, 2016 | 06:55 PM
  #91
fabfive's Avatar
That leather looks different than mine.
Is the stitching gone from the dash all-together? Mine has the double stitch where as I can see a faint pattern from the stitch on your dash leather.
I pretty much decided to make it a weekend project for the spring to take it all apart and bring it in to a local car upholstery shop after hearing the prices from some local Jag dealers.
Old Mar 2, 2016 | 07:12 PM
  #92
ABALaw's Avatar
Default Double Stitched
It's double stitched and in excellent condition. In fact the interior looks brand new. (I'm OCD about taking care of my property.) Anyhow, there is a phenomenal upholstery shop in LA. I think they can repair the dashboard for a few hundred dollars. That and the light bouncing off the dash at weird angels. Why Jag doesn't offer a recondition is beyond me. Requiring entire replacement of all hardware is insane as the hardware (dash backing and leather cover) are undamaged. It's just the glue / binding agent that failed. New glue / epoxy / etc works, better then new. They say it takes about four hours, total. At least Jag would save face by not appearing as trolls literally looting the piggy bank, because they can. Seriously, $3,500-$4,500.00 for a $400.00 as new recondition... That logic is beyond me.
Old Mar 3, 2016 | 07:08 AM
  #93
FastCat2011's Avatar
I'm going to catch flak for this, but so be it.
Safety issue? C'mon.. really? Temporary blindness? Holy cow.
It's ugly, yes.
Should it be happening in a luxury brand (or any for that matter), no.
Even with that being the case, trying to get someone else to pay the bill by claiming that the light bouncing off the rippled leather causes blindness is, frankly, abuse of the system.
There. I said it.
If Jaguar wants to attract or retain customers, they should be addressing this. It was an issue with my car and I had it replaced under warranty. But having said that, my dealership goes to bat for me and worst case addresses issues like this themselves. They also sell Rolls, Bentley, Maserati, etc., so they know the caliber of service people expect when buying those brands.
If my warranty was up, or specifically did not cover the issue, I'd be pissed, but I'd get it fixed using my own research and selection of a partner company or specialist. I'd pay the bill and move on. Maybe with a Jag, maybe not.
We all make choices about warranty. For me and my family, we put value on having a warranty. We pay for new vehicles and usually sell them before the warranty is up. If you want guarantees, buy new and and then comprehensive extended warranty. If not, unfortunately you need to take your lumps and move on.
My two cents...
Old Mar 21, 2016 | 12:29 AM
  #94
loco4myjag's Avatar
The funny thing about Jaguar not taking care of the 09-11 xf owners and our bonded leather wrap is that, coincidentally their facelift models 2012+ were fitted with staples... It really grinds my gears that they neglect the issue and then they add staples to the next model. For goodness sake I called jaguar USA in August 2015 told them my car had 40k mi and the dash was coming undone, that it seemed to be an issue for many owners. They said I didn't qualify for their program. I'm ready to print out this entire forum and take my car to the dealership so that they don't hit hit me with excuses.
Old Mar 21, 2016 | 08:04 PM
  #95
Quicktruck's Avatar
Banned
My '09 is like that - it came from S. Carolina
My complaint.
Old Mar 21, 2016 | 10:15 PM
  #96
boiler's Avatar
Someone mentioned last year some of the 11s may have left the factory with staples but when pressed on when in the run it happened they never answered. Jag may have done it without telling anyone, if that is true that should give us more ammo when the dash fails.
Old Feb 13, 2017 | 08:16 AM
  #97
Escolar's Avatar
Originally Posted by Blackcoog
I finally got some time to pull the dash out of my XF. I plan on attempting to lift the leather up and re-apply it. If it doesn't seem to be working I'll pay a upholstery shop to do it. The removal wasn't too bad. It took me a little over an hour. I snapped pictures of every step/bolt so the install wouldn't be difficult.
Blackcoog, My dealer quoted 8 hours to RnR the dash ($1200 just for labor). Would really love to see your series of removal pics.
Also, I called around a few trim specialists, and was given crazy high quotes ($1500+) and told it won't look as good as factory. Who glued your dash?
Old Feb 13, 2017 | 04:48 PM
  #98
Caribbeangirl7's Avatar
Unhappy Bubbling Dashboard, Crumbled Center Dash Grill and Flickering interior Lights
I sent a message out to the forum and i'm not sure if i did it right. I'm super disappointed with my vehicle in which i loved so much. I'm experiencing all of these issues not to mention how expensive the vehicle is. UGH!!! what can i do to get the dash fabric replaced or fixed. I took mines off but it's an eye sore right now i don't want to even drive it. I tried the glue thing no luck because the fabric shrunk. I drive my car down the highway and the interior lights flickers off and on UGH!!! My dream car is a nightmare now. SMH. Is anyone experiencing any of these. Where can i find the replacements. HELP
Old Feb 13, 2017 | 07:22 PM
  #99
BritCars's Avatar
No great suggestion on the dash unfortunately. You need a leather experienced upholstery store. If it's really bad you may consider asking them to make a fresh skin for it.
The flickering light seems to be a well known issue. Search around the forum - I think some people changed the lamps to LEDs and that fixed it.
Old Feb 14, 2017 | 08:51 AM
  #100
carzaddict's Avatar
dont think of it as a nightmare, think of it as a car with high maintenance characteristics, like a wife or gf. be thankful you dont own a laborghini, those guys pay $300k+ for an older model car that breaks down often
The dash is a common problem, if you do a search on the forum you'll see. but dont fear, do a little research and maybe you can find a mechanic that can fix it for cheap.
the overhead map lights are an EASY fix!! just replace with LEDs and you're done! i did it to my car, never flickered again.
