A/C oil charge
Old Mar 31, 2015 | 06:23 PM
Pierce's Avatar
Default A/C oil charge
I am replacing the condenser and compressor on my 2009 xf. The seal was leaking on the compressor, and I do not know how much oil to replace. I have flushed the system and need to know how much oil to replace in the a/c system. Any help is appreciated!
Old Apr 1, 2015 | 12:49 PM
tbird6's Avatar
Your compressor should have instructions to guide you.
Do you know how much oil the system is supposed to hold?
Do you know what kind of oil to use?
It's a bit of a guess because you don't know how much oil leaked out the front seal.
What I do if no information is to put 4 oz. in the compressor and 4 oz. in the dryer. Be sure and rotate the compressor by hand to move the oil around some. You don't want a big slug in the compressor and then hit it with the drive belt.
Now you don't mention replacing the dryer and it's MANDATORY anytime the system is opened or anytime anything is replaced.
Please add the dryer to your list. It's cheap and is really needed!
Also be aware that you can't flush a dual evaporator because it has a split flow path. The flush always has a way around any debris. So flush it but understand it's not purging all the passageways because of this split.
What does the returned flush look like? Hopefully very clean.
Old Apr 1, 2015 | 01:04 PM
As per Tbird, usually there is a sticker advising the capacity
Old Apr 1, 2015 | 03:29 PM
Pierce's Avatar
Thanks for the help! I went to the dealer this morning and talked to a tech. He looked the system up and it holds 4.3 ounces. I am replacing the drier, it's part of the condenser. Flush is clean. Thanks again!
silkcat
Jan 18, 2025 04:29 AM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Dec 4, 2020 07:55 AM
Jefro
Sep 15, 2015 01:44 PM
OkieTim
Sep 8, 2015 04:48 PM
