Can you install heated seats??
Old Mar 5, 2012 | 08:18 AM
jaguarsilke's Avatar
Default Can you install heated seats??
Hi.
I have a Jag XF 4.2 V8 without original installed heated seats.
My question is if anyone knows if it is possible to install the system so it will work with the normal activation on the touch screen?
I have asked my local Jaguar workshop and they are not completely sure, and I dont want to pay a lot of hours having them investigate if it is not possible anyway.
So if anyone know please help..
BR The freezing XF driver
Old Mar 5, 2012 | 12:34 PM
Rique's Avatar
If you disregard cost. The answer is YES. You will have to get a new set of front heated seats, then you must connect to car and have dealer install them and set up computer. If the car is preequiped with wiring to the seats you are in luck if not you will probably need a small extra harnes... its doable but will cost you.
Old Mar 6, 2012 | 12:39 AM
Thank you for the quick reply. It is really good news!! Now I am good with computers so do you know how to setup the car computer after installation? Maybe you can explain it to me? It is just because it sounded like that was there biggest concern when i asked in the workshop.
Thanks again.
Old Mar 6, 2012 | 08:29 AM
Rique's Avatar
I doubt that internal programing can be done with the car computer. You will likely have the dealer install a scanner and do the programming.
Old Mar 6, 2012 | 12:45 PM
cwood's Avatar
With a bit of basic wiring and products like below its pretty simple. The seat skins get pulled back and you lay them in. The wiring is just standard 12v with switches installed somewhere discrete. I had them in my cobra.
Automotive Seat Heaters
The switches give a couple heat levels and are very small so could be mounted on the sides of the center console etc out of sight.
H20boy
Dec 24, 2024 03:23 PM
kevinl
Oct 31, 2019 06:15 PM
adam699
Sep 12, 2015 05:32 PM
Bcrary3
Sep 3, 2015 03:48 PM
Dallas XK8
Sep 3, 2015 12:17 PM
