Central locking not working after battery re-connect
My front door locks quick working, period. The dealer told me that both my fuse boxes had bad relays. They needed to be replaced by the dealer. I was told that used fuse boxes would not function as the cars 'identity' was imprinted on the fuse box. They want $9000+ for the two fuse boxes. Has anyone else been told this about the fuse boxes?
I also had another experience a year or so ago now. My car was in for paint correction and - for whatever reason - my secondary battery went flat for a few days. I got the battery replaced, but by that point it had forgotten the keys. I had to have it towed to a dealer who (quickly) reset the keys. One of my controllers didn't reboot - but it's so trivial I don't really care - and every reboot risks making a junction box problem.
The reason I dropped back in is that one of the absolute technical stars of the Jaguar community based in Sydney mentioned the old 'junction box' excuse. This is a link to their FB feed https://www.facebook.com/oldjaguarau and scroll down to September 2022 (In case the forum software plays up, they are oldjaguarau on FB)
Hi everyone
I have the solution to this issue. I experienced exactly the same. I disconnected the battery to fit a dash cam, reconnected and boom, central locking doesn't work. Boot works, filler cap locks. I was having to manually lock the doors with the key, then set the alarm. This at least locked and alarmed the car.
The solution has been mentioned before. You need a Mongoose connector and a laptop with the JLR SDD software. Once installed, you run the Battery Replacement AND the Immobiliser module. It goes through a sequence of easy to follow steps, and click! EVERYTHING WORKS AGAIN.
I bought my Mongoose cable and software from a UK seller obd_software for £109.99. Now I know you can get these connectors cheaper from China, but I thought at least eBay has the return / refund guarantee if it didn't work.
Installing the software was long winded, but there is a video tutorial on how to do this given by the ebay seller. Once installed, I also ran into a problem with Microsoft Edge not running an Active X component, but the fix for this was to go to Edge settings and set the JLR SDD page it was trying to open as an Internet Explorer page. I will be happy to help anyone with more details of this step if needed.
I tried the battery replacement module first and although it resolved my ECO start which had stopped working from a previous battery sway out (bonus), central locking did not work. I then read on another forum to try the Immobilser module reset. Just tried it and YES!!
The SDD software looks a bit out dated and not the easiest to navigate, but the battery replacement and immobiliser modules are listed under a "recommended" tab.
I will be more than happy to guide anyone on this very, very frustrating bug in the Jaguar system that they have not seemed to take ownership of.
Nick
Nick
Spoiler
2014 XF250 facelift 2.2 UK Spec
SDD 138
Hope someone can help
I ran the SDD all nice and good, I ran the 'battery changed' and the check batteries, again all good.
But the keyfob still doesn't lock.
I scrolled step by step through all the service options and nowhere was there mention of the imobilizer (Imobiliser) so I can't run it.
Can anyone help me to locate this on the 138 please.
Much appreciated
63years 4 months, size 7.5 shoe, although 8 in sports shoes. No banana required. YES I';m a member of the dull men club!
SDD 138
Much appreciated
This was copied from another site............
Issue one most common:
Car won't lock after battery disconnect. This is solved via immobilisation in SDD.
Issue two less common:
Key not recognised at all hence no ignition, immobilisation not possible.
This is done via cluster reprogram as it will bypass the key sequence, turns ignition itself and do the immobilisation at the end.
This will also update cluster to latest software, bonus.
As I said,
I have the SDD, but there is no mention of immobiliser, which is why I asked :-)
The SDD JLR is a great way to do it but I ended up using the Autel I own. Did a run on “battery replacement” (both batteries) and “immobilization” and the locks started to work again. I’m sure if you visit a mechanic shop they have an OBD2 that is enough to run these test and I’m sure it will be much cheaper than what Jaguar will quote you!
Sono possessore di una Jaguar XF 2.2 Diesel anno 2015.
Sono state rimosse le batterie (principale e servizi) Installate le nuove, non hanno funzioneto le errature sportelli e portello bagagliaio. Non funzionano ne con telecomando ne con pulsanti interni ne con chiusura dello sportello. A volte faceva fatica all'accensione del motore. Le officine Jaguar (non conoscendo il problema) riferivano di avere la macchina per alcuni giorni per fare la diagnosi e sostituire (forse le cantraline). Purtroppo era un lavoro necessario. 200 euro solo per la diagnosi, poi il costo dei pezzi non funzionanti.
Sono stati provati molti metodi, staccando le batterie per alcune ore. Non c'è stato modo per risolvere. Improvvisamente non partiva più.
Senza acquistare oggetti o software, ho consegnato la macchina ad un amico (officina installazione impianti a gas/metano) che con la sua apparecchiatura di diagnosi (ultima generazione) è riuscito in pochi minuti a ristabilire l'accensione dell'auto e cancellare tutti i guasti. Adesso l'auto funziona perfettamente, le chiusure funzionano perfettamente e l'auto si accende regolarmente. Non è così cosa ha fatto. Con 5 minuti, senza cambiare pezzi, senza usare i vari software citati è riuscito a ristabilire la normalità (da quello che ho sisto ha effettuato il reset batteria servizi per 3 volte consecutive e improvvisamente si sono attivati i motorini delle chiusure. Possiedo una Jaguar XF 2.2 Diesel anno 2015. I own a Jaguar XF 2.2 Diesel year 2015.
The batteries were removed (main and services) New ones installed, the door and trunk locks did not work. They do not work with the remote control or with internal buttons or with closing the doors. Sometimes it had difficulty starting the engine. The Jaguar workshops (not knowing the problem) said they had the car for a few days to do the diagnosis and replace (perhaps the centrals). Unfortunately it was a necessary job. 200 euros just for the diagnosis, then the cost of the non-functioning parts.
Many methods were tried, disconnecting the batteries for a few hours. There was no way to solve it. Suddenly it would not start anymore.
Without buying objects or software, I gave the car to a friend (gas/methane system installation workshop) who with his diagnostic equipment (latest generation) managed to restore the car's ignition in a few minutes and erase all the faults. Now the car works perfectly, the locks work perfectly and the car starts regularly. I don't know what he did. In 5 minutes, without changing parts, without using the various software mentioned he managed to restore normality (from what I have gathered he performed the service battery reset 3 consecutive times and suddenly the lock motors activated).
