Check spare tire warning.
Old Sep 23, 2019 | 08:35 AM
harryf's Avatar
Default Check spare tire warning.
I received this warning recently. I have not checked the tire pressure much at all, but when I did, when the warning light came on it was definitely low. It's the space saver tire and the recommended PSI is at 60psi. I was in the 40's. So I pumped it up to 60. The Warning light however continues to go on, when starting the car. I'm assuming I have to manually reset the warning, with SDD, as there is no TPMS in the wheel and there probably is no sensor to measure it anyway. Is this correct?
Old Sep 23, 2019 | 10:16 AM
lotusespritse's Avatar
Possible the battery is dying in the tire sensor. I don't think my 2011 has a sensor in the spare. I always keep a portable 12v air pump in all my cars because there's nothing worse than needing to use your spare and it not having enough air to do the job.
Old Sep 23, 2019 | 01:54 PM
John Williams's Avatar
There's no sensor on the spare, must be one of the road wheels giving the warning!
Old Sep 23, 2019 | 01:57 PM
Brutal's Avatar
space savers don't have sensors, but the tpms modules for some reason get programmed or revert to having 5 sensors not 4 w/space saver. have you recently gotten sensor/sensors replaced? it ask when programming new sensors if there is a space saver. if answered no it will look the spare tire pressure from a full size spare. If you haven't you need to go to dealer to have programmed back to 4 w/space saver or ignore the warning
Old Sep 24, 2019 | 08:25 AM
carzaddict's Avatar
small $20 investment has saved my tail a number of times
Old Sep 24, 2019 | 08:44 AM
harryf's Avatar
Thanks Brutal. I did swap out the right side wheels. That must have caused the TPMS system think there were 5 wheels. Yes, I had 6 wheels in the car as I had the two wheels brought to my wheel refinisher and that must have reset it to 5 wheels. I'll have to get SDD out and reset it.
Old Sep 25, 2019 | 06:46 PM
harryf's Avatar
Brutal,
I did check SDD and it had no spare tire and the only 4 TPMS sensor blocks were available to fill in. Do you have any idea of how to reset this warning light so it doesn't come on anymore?
Old Sep 26, 2019 | 10:35 AM
Brutal's Avatar
I would try programming tpms module as new and see what happens . Have you already done a heard reboot of battery too?
Since you have sdd that would be my own line of actions to start with
Old Oct 11, 2023 | 05:30 PM
TreVoRTasmin's Avatar
Dragging this one from the dead as mine started doing this. Spare is a doughnut, did nothing to it as far as changing tires, wheels, battery, etc Not really happy with my local dealer at the moment as my wife's I pace is this close to requiring a lawyer to force a buy back on the lawn art Jaguar can't or refuses to fix so it actually charges so with the same issue going on since April. I don't really want to drive 2 hours to give 'em money to reset so has anyone figured out how to reset this at home. Gotta love nanny features.
silversurfer1221
Oct 8, 2017 10:08 AM
iownme
Sep 5, 2017 09:19 PM
Fairlane500
Jan 18, 2017 04:14 PM
tberg
Dec 18, 2015 08:43 AM
Ness925
Oct 20, 2012 04:04 PM
