Confirming the Correct Discs, Pads and Wear Sensors for 2015 X250 XF 3.0D S
Old Aug 13, 2023 | 08:23 AM
x2008type's Avatar
Default Confirming the Correct Discs, Pads and Wear Sensors for 2015 X250 XF 3.0D S
I am going to replace the front and rear discs and pads on my 2015 X250 XF 3.0D S - it has 355mm discs on the front as I believe all facelift (2012 - 2015) X250 3.0D S models had. Before going ahead and ordering, I'd greatly appreciate it if someone could confirm the discs, pads and sensors below are correct for the car.
Can I also confirm I will only need 2 pad wear sensors in total? (One for the front and one for the rear) Is the front pad sensor different given the discs are bigger than the rear?
Am I right in assuming I need to buy the pads with the piston clip?
What do Autodoc mean when they describe the pads as "without accessories?"
Front Discs: BREMBO COATED DISC LINE 09.B556.11 Brake Disc :
https://www.autodoc.co.uk/brembo/871...%20(09.B556.11)
Rear Discs: BREMBO COATED DISC LINE 09.B312.11 Brake Disc :
https://www.autodoc.co.uk/brembo/7611786
Front Brake Pads: BREMBO P 36 027 Brake pad set:
https://www.autodoc.co.uk/brembo/7280455
Rear Brake Pads: BREMBO P 59 042X Brake pad set:
https://www.autodoc.co.uk/brembo/18109743
Front Pad Sensors: BREMBO A 00 460 Brake pad wear sensor:
https://www.autodoc.co.uk/brembo/8217099
Rear Pad Sensors: BREMBO A 00 461 Brake pad wear sensor :
https://www.autodoc.co.uk/brembo/10567376
Many thanks in advance.
x2008type
Aug 13, 2023 03:33 PM
Stuart Mackinnon
Jun 3, 2017 11:17 PM
Humphrey
Mar 23, 2016 08:29 PM
macboots
Apr 6, 2013 11:32 AM
miamijag
Jan 29, 2012 10:23 AM
