Coolant Leak Rear Manifold
Old May 9, 2025 | 12:32 PM
Rob19321's Avatar
Originally Posted by aimulaidni
I thought so too but he said $600-$800 out the door, so I assumed it's parts and labor.
Does Dennis have videos online?
Thank you!
Hi, yes.
(Sorry Dennis, hope you ok me pushing your name and knowledge around a bit)
Go to his response, I see you can click a user, go there and there is a drop down search of posts and other things.
Do yourself a favor and watch everything yo have time for.
Old May 9, 2025 | 12:33 PM
clubairth1's Avatar
Community Influencer
You can change the thermostat housing but it's up to you. Will it fail? Maybe it's plastic.
I do have the metal version and I will be installing it in the future.
Old May 9, 2025 | 12:38 PM
Rob19321's Avatar
I'm with you about $1400 for just the rear manifold. The initial quote of $2000 seemed high. Yes, definitely something I don't want to push out.
Also, did you get any other components fixed when they had the supercharger out? I asked them about the front and rear together and they said that would be around $2700. This one seems high as it means they are charging me $1300 just to do the front manifold.
Thank you!
Yes, I did a lot more.
1. I put it in for the crossover pipes.
2. They suggested a timing job, minor rattling on the tensioner and I approved a full timing job. Please don't ask cost
(Probably would have been fine to not do this for 2 years, but I plan to keep the car so I moved the spend because they suggested.)
Others are more experienced than me, but the things I believe could or should be touched at that time.
3. Water Pump, simply because its critical and a known failure point and kills engines if people don't stop fast enough.
4. Belt, simply a cheap ish component that's already off
5. I think you'd get to injectors easier with S/c off but that deserves a separate post based on OEM and non-OEM part costs
6. .....guarantee there's a better posr on here iwht a list...
Old May 10, 2025 | 10:29 AM
clubairth1's Avatar
Don't forget the PCV diaphragms while the SC is off. They are too cheap. I use the after market ones that are made from a better elastomer hopefully they will last longer.
They claim they use military grade Fluorocarbon. I have a pair installed on my car. So far no complaints.
PCV Diaphragms
Old May 12, 2025 | 05:54 AM
Rob19321's Avatar
Sorry Dennis, hope you don't mind others tlking about you while you on the thread.
Subscribe to this: https://www.youtube.com/@den-tech-mods
Old May 14, 2025 | 01:24 PM
dennis black's Avatar
20 Year Member
No problem my friend, here to help everyone, ill have another video on parts list and diagnostic tools ,and how to read the pids and values
pk4144
Oct 16, 2021 11:31 AM
XtypeHI
Aug 6, 2021 04:53 AM
prados85
XF (X260)
Jun 5, 2021 08:36 AM
David Dulson
Jun 4, 2020 01:51 PM
hirev
Oct 25, 2018 05:56 PM
