Different emblem
Old Oct 5, 2015 | 12:17 PM
n8ertot's Avatar
Default Different emblem
So I saw this emblem on ebay and liked it. When I got it, I wished it was a bit bigger, but still preferred it over the existing leaper. Thoughts?
BTW - it had just stopped raining and I was doing a bit of car work, so please don't judge me on the dirt!
Old Oct 6, 2015 | 06:54 PM
2010 Kyanite XFR's Avatar
I'm not feeling it, but to each his own.
Old Oct 7, 2015 | 06:05 PM
n8ertot's Avatar
Fair enough. I just liked this. Feels cleaner to me that it's framed and even.
Old Oct 7, 2015 | 07:28 PM
OzXFR's Avatar
But it's pointing the wrong way!
Just joking.
I notice that your trunk/boot doesn't line up all that well with the lights, I had the same problem on my old XFS and to a smaller degree on the XFR, and same as you mainly on the RHS.
I found there was no way to lower the boot lid by much, but I improved the appearance of mine a lot by lifting the height of the light assembly a bit.
Just remove the light assembly (easy - undo three 10 mm nuts inside the boot and unclip the wiring plug) and pack out the bottom of the assembly with one or two bits of Velcro, the "soft" part. You only need one or two small pieces.
I had to experiment a bit with the placement and thickness of the Velcro before I got it right.
Old Oct 7, 2015 | 08:57 PM
n8ertot's Avatar
Just joking.
Thanks, fellow neurotic! I've had a twitch about that every time I looked at the car from the back end. I'm glad to hear somebody found a solution. I didn't want to raise the boot and have the edges not line up, so I didn't even look into that.
Ferdie
Nov 26, 2018 05:42 AM
sunchip
Oct 5, 2015 02:05 PM
Hex Type
Oct 5, 2015 04:38 AM
jazzydog
Oct 4, 2015 04:06 AM
