Donny Ensley 2014 Jaguar XF 250 V6 3.0 s/c
Old Nov 24, 2019 | 11:38 PM
Carl Carl's Avatar
Default Donny Ensley 2014 Jaguar XF 250 V6 3.0 s/c
I pulled the supercharger. To get to the notorious tube that goes underneath the supercharger replaced it. but when I put the whole thing back together I found by the throttle body there's a coolant tube that has a y on it. That y isn't connected to anything. comes right off the coolant Reservoir. Anybody know what that might be? And I don't know if I missed putting the hose on that when I put it all back together and it's a hose that runs underneath the supercharger I'm not sure?
Right there in the middle of the picture by the throttle body.
Old Nov 25, 2019 | 12:24 AM
OzXFR's Avatar
My F-Type V6 looks exactly the same so I don't think you have missed anything.
Of course that doesn't explain the mystery of the extra ribbed protuberance!
Old Nov 25, 2019 | 01:27 AM
Swilmer52's Avatar
Nothing goes connected to the ribbed end of the Y Fitting. It is oddly plugged/blocked.
Old Nov 25, 2019 | 04:22 AM
Carl Carl's Avatar
Thank you guys I appreciate that... I was stressing out big time. Got another question to though. Some of the bolts got used on different areas then where they originally came from is that going to be a problem
Old Nov 25, 2019 | 10:16 AM
Carl Carl's Avatar
So quick question? So everybody knows about the supercharger.
now I'm trying to figure out if I should fill that Reservoir all the way till it's full because I have no idea how much was in there a lot of it spilled out.
Old Nov 25, 2019 | 01:59 PM
Jssaab's Avatar
What resovoir? OIl you mean?
Its 5.1 oz when the SC is new. It's good to see how much comes out since it is sometimes hard to drain all of it.
Use ONLY Eaton SC oil
Old Nov 25, 2019 | 02:00 PM
Jssaab's Avatar
Use only Eaton SC oil
Johnny Mayday
Jun 18, 2017 09:08 PM
Cherry_560sel
Nov 26, 2016 01:15 AM
Lannyl81
Oct 3, 2015 09:03 PM
steuey67
May 28, 2012 09:25 PM
achysklic
May 7, 2011 08:17 PM
