Doors
Old Apr 21, 2013 | 06:24 PM
Brazz's Avatar
Default Doors
Recently the two front doors need a hard pull from the outside when entering and a strong shoulder bump from the inside when exiting to open. Strange. If I wasn't the only owner I would think the car was wrecked and out of structural alignment. Has anyone experienced this? Thanks. 2012 XF Portfolio Sport
Old Apr 22, 2013 | 08:40 AM
jagular's Avatar
The exterior door handles are Volvo items and are known to stick. However, if the same trouble arises when opening from the inside it is not likely the door handles.
Have you considered cleaning and lubricating the door seals?
Old Apr 22, 2013 | 09:22 AM
Blackcoog's Avatar
Sounds like the latch isn't matching up. The door must be sagging. Try lifting and then opening. If that helps the door/latches need to be re-adjusted. It's unlikely both front doors would have this issue so that's very odd. Make the dealer take care of it.
Old Apr 22, 2013 | 11:56 AM
Brazz's Avatar
The car is at Jaguar now. I won't be touching the seals. I've had too many seal issues. It's feels mechanical. We'll see....
Old Apr 22, 2013 | 01:36 PM
XJL's Avatar
XJL
Let us know the outcome....very odd!
Old Apr 22, 2013 | 05:55 PM
Brazz's Avatar
Just got the car back. They adjusted the door "rockers". The doors close normally now.
Old Apr 22, 2013 | 07:13 PM
jaguny's Avatar
Ok, what's a door rocker?
Old Apr 22, 2013 | 09:41 PM
Brazz's Avatar
I will post a picture
Old Apr 23, 2013 | 07:08 AM
Blackcoog's Avatar
Rockers could be the lower portion of the door or even the sill the door slides over when shut. I wouldn't have thought any of that was "adjustable" unless it was loose.
Glad to hear it's fixed.
Old Apr 23, 2013 | 08:17 AM
Brazz's Avatar
Sorry... They adjusted the door "strikers" .
Old Apr 23, 2013 | 08:48 AM
jagular's Avatar
That makes sense. Blackcoog earns the prize for accurate diagnosis.
Old Apr 23, 2013 | 12:29 PM
Blackcoog's Avatar
Woohoo!
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
al_roethlisberger
Sep 21, 2015 08:07 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
