Engine Sensor
Old Jan 13, 2020 | 09:45 AM
Paul Gronowski's Avatar
Default Engine Sensor
I discovered a leak coming from this part. Looks like oil. What is this?? I have a Jaguar XF 2009 premium luxury
Leaking from this part
Old Jan 13, 2020 | 07:18 PM
pdupler's Avatar
I don't have the same engine, but that looks like the VVT solenoid on my xj8. Common spot to leak. If its like my xj8, its got a lip seal pressed into the valve cover. Its not very expensive (only like $6 for the aftermarket version on rockauto) and you should be able to pry off the old one and press in the replacement without removing the valve cover.
Phil
Old Jan 14, 2020 | 11:53 AM
Thanks phil I was hoping it was an easy fix.
Cheers!
Paul
Jon89
Aug 27, 2019 12:11 PM
Sean W
Jun 7, 2019 05:19 PM
daro31
Sep 16, 2018 02:25 PM
jgonzalez2002
Jul 24, 2018 01:17 PM
banar
Jun 15, 2018 08:43 PM
