Engine swap xf v8 5l
Old Nov 30, 2022 | 06:57 AM
Rique's Avatar
Default Engine swap xf v8 5l
My engine finally failed after a left head gasket blew. I think replacing the gasket is too much of a job. I have found good used engines in the 4 to 5K I donīt know if new ones are available.
I understand that for 2011 to 2014 engines are same with letter B on 8th position on VIN number. Has anybody completed an engine swap before in this forum. I understand that removing engine is not
as complicated as removing valve head with engine in vehicle and that its reasonable job all considering and that no further computer work is needed.
Appreciate any comments.
Old Nov 30, 2022 | 02:03 PM
kansanbrit's Avatar
I have the engine out of mine now to fix the head gasket. I just had the head straightened but in needs new intake valves so waiting on those currently. The same engine is in the Range Rover except cams are different. If you do swap I would buy your old one if in US, I have rebuilt 4 so far. Let me know if I can help.
Old Nov 30, 2022 | 07:19 PM
Rique's Avatar
You fixed 4!.Wow man Respect! Well if you can let me know the following.
1. It seems removal is straight forward as your picture shows. Remove Exhaust, Drive shaft...
2. Once you put new one in of similar VIN do you have to fiddle with software or something?
3. How many hour did you take to drop it and put it back in.
Thanks much and regards
Old Dec 1, 2022 | 10:39 AM
kansanbrit's Avatar
Here are the basic steps.....
https://drive.google.com/file/d/1-zzjWpxYZyL4Yo81G68g0uEBmgQiMVFU/view?usp=drivesdk
No ECU work needed.
Old Dec 1, 2022 | 05:12 PM
karamayoko's Avatar
nice document Kansan. Maybe moderators should consider it to be a sticky considering its some useful information.
Old Dec 15, 2022 | 03:50 PM
Rique's Avatar
Great info appreciate your input
Louie Dachshund
May 8, 2019 02:18 PM
chevynova410
Oct 28, 2014 08:44 AM
Jhnbrunton
Dec 2, 2013 01:33 PM
shawnethan
Apr 6, 2013 04:06 AM
03jaguardown
General Tech Help
Dec 27, 2009 11:08 AM
