Error code P0512
Old May 15, 2015 | 05:02 AM
Geoff1965's Avatar
Default Error code P0512
Good morning,
I am a new user in need of your assistance. I have a XF 3.0d that is currently in a sad state. The story is long, but in order to get to the point I will go over the key points. It started with a fuel gauge that intermittently stopped working, which resulted in it going to the dealer to have a modification on the fuel sender and the fuel pump (a known issue the dealer said). It was also services at the same time. 200 miles later whilst driving along a duel carriage way, an engine fault light came up on the dash board; the engine shut down and would not restart. The AA collected the car ran a couple of tests and concluded that the fuel pump had failed. Back to the dealer who concluded that the fuel pump was fine, but an injector / injectors had failed. This was then revised to not only the injectors but the high pressure fuel pump as well. With an anticipated repair bill of £8,000 from the dealer (which I could not afford) I had the car taken to a local garage that have carried out the work. I now have a problem, in that the car will not start and is showing an error code of P0512 which we have to date been unable to trace. Can any of you give me a guide as to what this code means and what may be causing it?
Geoff
Old May 15, 2015 | 06:28 AM
OzXFR's Avatar
According to the web page I use for error codes, P0512 = "Starter Request Circuit", see here: OBD-II DTC Database - Generic Powertrain Codes (P0xxx, P2xxx, P34xx - P39xx)
If that is correct then it seems there is an electrical problem with the starting system.
Old May 15, 2015 | 07:11 AM
Geoff1965's Avatar
Thank you for that,
We have checked through the wiring and connectors and everything looks to be correctly connected. It’s got a new high pressure pump and six new injectors, plus all pipework and rails.
It turns over, but will not start; do you have any suggestions as to where to go next with our problem?
Old May 15, 2015 | 06:24 PM
OzXFR's Avatar
Take it to an automotive sparky and get him to test the starter electrics.
Bcrary3
Feb 21, 2023 04:29 AM
Terry H
Jul 4, 2017 05:48 PM
KarimPA
Sep 27, 2015 08:46 AM
Jpav27
Sep 26, 2015 03:33 PM
tonyforman
Sep 10, 2015 07:23 PM
