Exhaust tips
Old Mar 25, 2023 | 03:07 PM
RochaSDS's Avatar
Default Exhaust tips
Hey all,
I live in Portugal, but I work abroad (Netherlands).
I'm abroad now so I can't go out to my car to measure the exhaust.
Can someone help me out and give me the diameter of the tailpipe, after the last muffler.
I want to buy a couple of dual exhaust tips from AliExpress, but they've got all different sizes. Not sure which one's to buy.
These things are slip-on and clamp, so could I get the outside diameter of the pipe?...maybe a photo from underneath also?
Not sure if it matters, 2013 XF 3.0 SC
Old Mar 26, 2023 | 05:22 PM
Nansan21's Avatar
Hi, the diameter you need is 63mm inlet...many of the exhausts on offer on Ali are fairly long (250mm) from end to end and sometimes extend too far out and don't blend in well with the body. I went for the oval tips on my V6.
Old Mar 27, 2023 | 01:24 AM
RochaSDS's Avatar
That's exactly what I needed, Thanks for that.
Old Jul 9, 2023 | 03:06 AM
RochaSDS's Avatar
Thanks for your input.
I bought a caliper and measured my exhaust pipe right after the muffler (just before the tip) and it measured 60mm OD.
I got the tips from AliExpress (60mm ID) x 89mm double, but I modified them to suit.
Took the rivets off to remove the carbon outer part, painted the inside yellow to match a few other yellow highlights on my car.
Also, because they are too long, at 250mm overall length, I cut back a few mm and cut new slits to allow it close tight over the existing pipe, just enough for the bracket to grab on and hold it in place
This is the result.
karamayoko
Nov 7, 2022 10:36 AM
Jaguar1611
Dec 10, 2021 02:39 PM
NYCJAG2006
Jul 23, 2020 12:12 PM
srpope80
E type ( XK-E )
Feb 1, 2018 04:18 PM
Magnumforc
XF (X260)
Jan 11, 2018 08:21 PM
