External from Dash / Display Screen
Old Oct 24, 2023 | 06:09 AM
RochaSDS's Avatar
Default External from Dash / Display Screen
Here's a head scratcher, for me at least.
If someone has already dismantled their head unit, would anyone be able to tell me what kind of connections there are to the back of the screen?
Does it only have the ribbon cable or is there an additional power cable?
This also depends on the number of pins the ribbon cable has??? It may already have power from the head unit???
I already have wireless android auto and carplay added through a little box I bought from a local seller which works fine, but the screen, oh Jaguar, the screen is tooooooo small !!!
I had this crazy idea that I wanted to get something like the Tesla Screen sold on Aliexpress, but I don't want to mess with wrapping the textured parts of the dash to make them all match. (can of worms senario).
So I kept on searching and found another type of screen which kind of sticks out from the dash, of course because it larger at 8.4"
The bezel is just too big (I just threw up a little in my mouth ) and it looks like a screen from a Renault Clio. Yeah, I'm in Portugal (Europe) so we have those here.
There must be a better way.
Something like this, but this is only available for the more recent models, Mine is a 2013 XF.
I'm all about DIY, so if someone can help me by sharing information on the internal connection to the display screen, I can go out and look for a similar screen technology, but somewhere around 13" with minor bezel and build my own bracket to connect it to the existing head unit.
I understand there are all kinds of different opinions of what looks better and what is OEM or not, but thanks for your help and comments.
Old Oct 24, 2023 | 06:29 AM
RochaSDS's Avatar
After all that blah-blah, what I need is to know how many pins the ribbon cable has?
Old Oct 26, 2023 | 09:14 AM
Noelmid's Avatar
Default Display screen connections
Hi, I removed this from my XF 2.2d 2012 because it stopped working. I bought a used replacement from eBay and all's good now. Hope you can make out all the connections you are looking for. Good luck! Noelmid
Old Oct 26, 2023 | 10:18 AM
RochaSDS's Avatar
Hey Noelmid,
Thanks for the input, but what I'm looking for is the inside ribbon cable between the main unit and the screen.
There's a guy who replaced his screen for an 8.4" and he actually has a few videos showing step by step.
Old Oct 27, 2023 | 12:33 PM
fivel's Avatar
Like this?
Old Oct 27, 2023 | 01:14 PM
RochaSDS's Avatar
Thanks,
So from what I understand in the 3rd picture, on the right, the display still has another circuit board attached to it's back, then the ribbon cable comes out of that circuit board.
Shoot, this probably isn't going to work the way I was thinking it could.
Old Oct 27, 2023 | 03:31 PM
fivel's Avatar
Originally Posted by RochaSDS
Thanks,
Yes. There's a 40 pin connection from the central board to the screen driver, I'm guessing it's some sort of LVDS / TTL signal but I've not checked. The screen driver board has a bunch of stuff going on, I'm not really sure why, but ends up with something like 60 pin connection to the screen. Seems like overkill.
Old Oct 27, 2023 | 03:34 PM
EliteZags's Avatar
1. looks like the interior of a high end 2002 Buick
2. looks like a children's tablet
Old Oct 27, 2023 | 04:27 PM
RochaSDS's Avatar
Yeah, right?
The larger screen with sharp corners and almost no bezel looks much better.
Old Oct 30, 2023 | 09:50 AM
RochaSDS's Avatar
I'm getting little further with info off Google.
Because the display isn't multi-touch, I'm thinking it's a 4-wire resistive screen. If it were multi-touch it would either be a 5 wire ribbon cable or it would be a capacitive screen which I don't think it's either of those two.
So I've narrowed it down to 4-wire resistive.
Can you confirm this?
Old Oct 31, 2023 | 01:37 PM
MrRimmer's Avatar
I've also got the second one. True, it does have an oversized bezel which should have physical buttons in it oo justify the size. Having said that it doesn't look as bad in real life as it does in the pictures as it is quite tight to the dashboard and doesn't block the vents.
Old Nov 21, 2023 | 06:09 AM
RochaSDS's Avatar
Update:
So I ended up just buying one on ebay to avoid having to dismantle mine just to investigate and decipher what's going on inside.
This is what I can see so far, but I have to go deeper because I wasn't expecting so many ribbon cables.
My idea is only to replace the outer touch display with a larger one, maybe 12.1", which seems to be a standard size.
Any thoughts as to what these three ribbon cables are for, or maybe someone has a diagram?
Skyview
Oct 13, 2023 08:54 AM
sundaram
Dec 15, 2022 07:24 AM
EsRay
Aug 22, 2022 10:55 PM
MySuper8Jag
Dec 17, 2021 11:41 AM
Ish
Feb 28, 2015 02:40 AM
