Front door lock removal, help required.
Old Jul 3, 2016 | 04:51 AM
hoylegj's Avatar
Default Front door lock removal, help required.
Hi,
I'm trying to remove the drivers door lock from my 2010 XF and failing.
I've read the manual, and just can't see how to get it past the window mechanism.
Anyone succeeded ?
This should be easy, but don't want to break it.
Many thanks
Old Jul 3, 2016 | 05:09 AM
OzXFR's Avatar
This vid is for the rear door lock, but the basics should be the same for the front door lock:
Old Jul 3, 2016 | 02:40 PM
hoylegj's Avatar
Thanks sorted, it's easy... The bit the manual isn't clear about is you need remove the window... Open wind 3/4 inches. You can then reach in to spring the window clips back and use 2 thin bits of metal to to keep the from springing back. Then lift the window out.
The rest is easy.
Old Dec 7, 2019 | 09:04 AM
AliceSean's Avatar
Take locksmith's help in removing the door lock, they will be able to do it with perfection.
dwclapp
May 28, 2021 04:34 AM
Carleden1980
Oct 6, 2019 02:11 PM
hoylegj
XF (X260)
Jul 3, 2016 07:25 AM
dwclapp
Dec 20, 2010 10:16 AM
booyaford
XJ40 ( XJ81 )
Sep 27, 2009 09:45 PM
