Front License Plate Solution
Old Oct 7, 2017 | 01:09 AM
FightinIrish2003's Avatar
Default Front License Plate Solution
Jaguar XF 2016. Washington is one of those states that require a front plate and, unfortunately, enforces quite aggressively. Can someone recommend a solution that doesn't require drilling holes in the front bumper of my beautiful XF?
Old Oct 7, 2017 | 01:50 AM
OzXFR's Avatar
Head on over to this thread in the F-Type section: https://www.jaguarforums.com/forum/f...light=sto+show
I don't know if one of these would work on an XF but worth asking about.
Old Oct 7, 2017 | 03:26 AM
Zamir Chatur's Avatar
I use the RHO tow hook license plate.
Old Oct 7, 2017 | 01:06 PM
Thank You!!! I saw this on ebay earlier, good to know that these guys are legit. Ordering now...
Old Oct 7, 2017 | 01:18 PM
BTW, your F-Type looks fantastic! It is one of the best looking cars out there, IMO.
Old Oct 7, 2017 | 02:16 PM
stmcknig's Avatar
The other option for the XFR is https://skenebrackets.com
I had this on mine - it does drill into the bumper but underneath so it's not visible if/when you remove the front plate.
Old Oct 10, 2017 | 03:00 PM
thap143's Avatar
Default Watchout for the sensors
Careful if you have 4 sensors like mine. The towhook plate holder had to be precisely placed in an angle to avoid the beeping every time you started up. There are multiple versions on ebay get one which can turn on the hook and not rigid.
Old Oct 10, 2017 | 07:44 PM
allenman85's Avatar
Yes! Move to another state!
Thankfully the Dallas area cops don't have time for enforcement of this but boy it took no time at all to get pulled over south of here because of no plates. I won't drill the front and would play dumb in the future. The plate is in the front seat just in case I get pulled over again. Front plates make no sense at all to me if only *some* states require them. Would they chase down an out of state car just to find out it does not need plates????
Old Oct 10, 2017 | 10:26 PM
davetibbs's Avatar
This This
may be a neater solution, providing space can be made inside the bumper. I'm considering it...
Old Oct 12, 2017 | 06:29 AM
Adam J's Avatar
i looked at all the options as well. ended up cheaping out and bought / cut / heated / bent / fastened to car a piece of aluminum stock from home depot. car had lived its life in PA and i didn't want to drill front for NY compliance.. it worked for me and, as added benefit, doesn't block radiator or bumper sensors.
Attached Thumbnails Front License Plate Solution-20171012_072327.jpg   Front License Plate Solution-20171012_072331.jpg
Old Oct 12, 2017 | 09:10 AM
alinton's Avatar
Here in Ireland - and the UK - all cars have to have front license plates, unfortunately.
I hate having to drill bodywork, but sadly my car had this done previous to my ownership. And when I removed the plate to change it I found it had been done twice - four holes.
I'd much rather use some form of hidden fixing like the above. If I ever get the bumper resprayed to cover stone-chips etc I'll get the holes filled first.
A
Old Oct 13, 2017 | 07:40 AM
2010 Kyanite XFR's Avatar
When I had my front bumper resprayed last year, I bought the Skene mount. I still haven't put the mounting bracket or the license plate back on the car because it looks so much better without it. I'm officially gambling though, and if I do get ticketed, I'll take care of it.
I have noticed a large number of higher end cars with no front plates, so I'm hoping the LEO's are just not enforcing. My neighbor is an officer and he said they don't really care much unless you give them a reason.
Philco
E type ( XK-E )
22
Mar 17, 2025 12:10 AM
Mark SF
Dec 13, 2016 04:51 PM
S4OC
Oct 5, 2016 10:03 AM
sjuraud
Aug 28, 2010 02:11 PM
Feb 7, 2007 08:52 PM
